ECU Tuning Group | Jaguar F-Type Pulley Installation
We can only comment on OUR tuning and OUR customers. If any of our customers had any issues they are more than welcome to post their experience and invoice number here.
We do so many of these cars a week. Since 2009, we have not once heard from any of our customers that our tune has been detected.
For us this discussion is closed until someone posts an invoice number.
The ECU controls engine and transmission side of the supercharged engine system. But ultimately the drive ratio for the supercharger is set by the relative size of the pulley wheels....that can't be changed by the ECU.
The easiest way to change the supercharger blower drive ratio is to reduce the size of the blower pulley wheel, so that it spins faster per engine RPM, forcing more air into the engine, allowing for different air compression and fuel mixes (which are controlled by the ECU engine-side....so the pulley change needs to be accompanied by an ECU remap).
Note that the engine is actually doing the work of spinning the blower (via the pulley system), so you are giving up quite a bit of fuel efficiency by increasing the supercharger drive ratio.
The Torque curve on the V8 is a 'table-top between 2500-5500rpm. As this engine has a mechanically driven supercharger, it ought to be an inverted u-shape. This strongly suggests that boost is being bled off between the 2500-5500rpm to maintain a constant level of boost and torque (with the help of appropriate fuelling and ignition timing).
Sticking a smaller pulley on the supercharger, but making no other changes will extend the table-top to the left, but probably at the expense of the right hand side as the efficiency of the supercharger drops off earlier as it is spinning faster.
Additionally, as you mention, driving the supercharger faster is going to soak up more of the engine's output.
So, back to the original question: Wouldn't it be more effective on this engine to leave the pulley as is, and make changes to the software so that boost isn't limited? Projecting the edges of the table-top suggests a peak of 675Nm @ 4000rpm would be the result before you start optimising the fuelling and ignition timing.
Questions? Comments?
To the gentleman questioning the pulley installation, I have done quite a few myself & never had a problem. The only thing we did differently was instead of using a torch we put the pulley in a toaster oven for 1/2 an hour on 350. The pulley will slide on just make sure you slide it back as far as the original.
To anyone out there with doubts on the pulley & tune, just do it. It makes a world of difference. You will be truly amazed how much faster the car is.
Imagine what the R could do w/tune & pulley.
Ferrari 458 Italia, Chevrolet Corvette Z06, Mercedes SL63 AMG (Top 3 fastest stock RWD Super car) - YouTube
Did you catch this one?
So my R which starts out with over 50bhp more than the vert, ends up with only 10bhp more and for the same money.
Doesnt sound great to be honest, why isnt the tune comparative to what they both start with!!!
Lawrence.
Your feedback would be really interesting if you go ahead with this. I might consider it next spring.
Lawrence
Lawrence
When it comes to the R, we only recommend it with a pulley. Even though Jaguar states 550hp the car measures lower (520-530hp), with the ECU tune only the car ends up at 575hp.
I suspect the reason folks try not to exceed the tabletop is for risk management. You can "borrow" from the right side of the tabletop, but if one just goes above the engine performance envelope you risk serious engine damage, for example the engine may run hotter than the cooling system can compensate for and you end up with one of those awesome melting videos
From the ideal gas law, pressure x volume / temperature is constant, so by introducing greater pressure into the chamber (via supercharging) and more fuel (to match the added pressure) operating temperature goes up also. So the entire engine runs hotter. To achieve higher power at lower RPM with the same engine on the same octane fuel, you have to increase pressure and optimize air-fuel ratio....but as you do this temperature necessarily increases also. So limiting the output for a given RPM is the easiest way to keep the engine within acceptable operating limits.
