Eibach Springs+ Bilstein B4= OEM+ Upgrade
Old Apr 22, 2025 | 01:15 PM
WhiteTardis's Avatar
Default Eibach Springs+ Bilstein B4= OEM+ Upgrade
Finally decided to pull the trigger on lowering my F-TYPE using Eibach springs. (Part Number#E10-45-007-01-2).
I figured since my car has 60,000 miles on it, I'd go ahead and also replace the factory shocks and go with the Bilstein B4s and all the parts attached to the shock absorber. I envision this to be an OEM+ style of upgrade; think Nissan Nismo, Toyota TRD, etc. Just a mild drop along with maybe a slightly firmer ride. On that note, does anyone have experience using the Bilstein B4s? (non adapative suspension)
Benefits are..having a refreshed suspension but not having to disassemble and transfer everything from the old setup to the new setup.
For the front, the suspension components that would be replaced are #4,6, and 7 (shock absorber will be the Bilstein B4 and the Eibach spring)
For the rear the suspension components that would be replaced are #10,9,8,7, and 5 (shock absorber will be the Bilstein B4 and the Eibach spring)
Old Apr 22, 2025 | 02:35 PM
lizzardo's Avatar
I'm not sure about the base suspension but the adaptive suspension uses Bilsteins from the factory.
lilmountain
Jan 21, 2025 03:34 AM
brianshaw009
19
Jan 11, 2025 01:11 PM
vincent661983
Oct 8, 2024 12:19 PM
Vedemin
Jul 31, 2024 05:49 PM
GordoCatCar
May 6, 2008 10:10 PM
