Engine Guard / under tray
Is the Engine guard / Under tray the same part on all models?
More specifically does anyone know if there is a difference between the tray for the R Coupe and the SVR Coupe?
The reason for asking is that I propose to fit an SVR front bumper assembly on my 2014 R Coupe!
Just got this from UK Forum. This guy is fitting an SVR front to a 2WD F-Type
cj10jeeper » Thu May 11, 2017 3:45 pm
Not correct as I have a 2wd and alignment is perfect, or out another way I can't see anything and would expect the difference to be in crease lines where they blend from bonnet centre to bumper.
Now granted that doesn't mean much as manufacturers change profiles to differentiate, so different markets model years and designations may change the fit.
For future reference here's my V6S undertray next to the SVR that is now fitted. Aside the leading edge profile which is completely different the rest is identical in profile. Every crease, curve and fixing mates perfectly.
Seems to me that man early 2WD is the same as a current SVR
One difference is the extra cooling on the SVR which aligns to the aux rad
Unless you are racing, you might consider ditching the undertray.
I removed mine, along with the engine cover and drilled out the hood vents... lots of heat pours up through those vents now.
Lawrence
Lawrence
With that panel removed you may be reducing the airflow through the radiator and compromising the aerodynamics. I'd think twice before tossing that.
Two years now and all good. I seem to recall that Jaguar left it off the XKRS as well, from the factory.
Lawrence
I cannot even contemplate why you'd leave the undertray off a performance car
It's key to airflow under the car which affect stability, mpg and more
its structural to the bumper and wheel arch liners keeping the whole thing stable
it keeps road debris and dirt off vulnerable parts Inc the aux rad.
it's almost certain to impede cooling as the airflow ifs carefully balanced including the low pressure area under the car pulling tensor down and out
Im sure drives just fine and none of the above is noticed, but not how designed and achieving nothing
