Engine start warmup times
Old Oct 1, 2020 | 09:52 AM
madmax1911's Avatar
Default Engine start warmup times
I have owned this car for a year now and since the beginning I have thought the high idle on initial startup was excessive.
Regardless of ambient temp the car stays at high idle for what seems like an eternity on initial startup or if the car sits for an hour. No other vehicles I have owned stay at high idle this long unless it’s really cold outside and the idle times are much shorter in the summer, but the Jaguar doesn’t seem to care about the ambient temp.
Is this normal or something that can be adjusted in the programming?
The ambient temp was 86 F for this startup.
Old Oct 1, 2020 | 10:24 AM
scm's Avatar
scm
Not sure what your image is showing, but my idle drops within a minute of startup, often less time when warm.
Old Oct 1, 2020 | 02:02 PM
madmax1911's Avatar
Stayed at high idle for one minute, three seconds.
I am not talking about the initial vroom at startup, I am measuring the sustained high idle of about 1200 RPM’s before it drops back to normal RPM.
Old Oct 1, 2020 | 02:36 PM
Burt Gummer's Avatar
If it bothers you or too noisy move the shifter to drive or reverse then back to park again. I have to do that regardless early in the AM so neighbors don't revolt.
Old Oct 1, 2020 | 02:47 PM
scm's Avatar
scm
That's what I'm talking about, too. If I remember(!), I'll time mine next time I start it. I've never considered mine to stay at high revs for an excessive time, though.
Old Oct 1, 2020 | 09:22 PM
madmax1911's Avatar
I have done that a couple times but thought maybe it wasn’t the best for transmission?
Old Oct 1, 2020 | 09:24 PM
madmax1911's Avatar
Thanks, I am really just curious more than anything but the long startups are a bit annoying.
Old Oct 1, 2020 | 09:39 PM
OzXFR's Avatar
Mine drops from around 1,200 rpm at cold start up to the normal idle rpm of around 650 in less then 20 seconds almost every time I start it.
Staying at 1,200 rpm for a minute after start up just seems wrong to me unless the ambient temp is waaay low.
Old Oct 1, 2020 | 09:53 PM
StormtrooperFtype's Avatar
ya mine stays up fairly long as well, but like someone previously said, once you put it into gear it will drop down, but if you do it right at the beginning it will lunge you forward. Tmmr morning I will time how long it takes my V6S and get back to you.
Old Oct 2, 2020 | 07:09 AM
madmax1911's Avatar
That’s how my other vehicles behave also.
Old Oct 2, 2020 | 08:00 AM
Therock88's Avatar
Mine idles up pretty high for quite a long time as well. I think it is normal. Would not worry about it. It lasts about the same as my 997 TT and Cayenne S, so not worried. Gets that oil pumping through the engine before you pull off.
A minute is not very long....."That's what she said" ...
DC
Old Oct 3, 2020 | 07:24 PM
supersportmtl's Avatar
DC
LOL
my car idles for a minute as well! 1 minute 3 seconds is what it takes to get the job Done ✔️
Old Oct 4, 2020 | 10:28 AM
scm's Avatar
scm
I timed mine from stone cold - 1 minute 1 second.
Old Oct 4, 2020 | 08:17 PM
Taylorguy74's Avatar
Mine did 33 seconds start to idle this Saturday at 5 AM stone cold - not started for 6 days. Garage ambient temp was 74, outside 59.
Restest - same day, Saturday late evening (9P) after sitting all day for detailing inside with doors open until 6 PM when sun hit rear of car during detail - cold start at 76 degrees ambient, outside at 79 with high of 83 for the day, to idle - 31 seconds.
Rougly the same as all our cars from cold start inside insulated garage to idle. We never put into gear until steady low idle.
Old Oct 4, 2020 | 08:29 PM
Madscott's Avatar
Never timed mine, but it always seemed excessive. Especially when I was ready to go, but I never wanted to cut it short, as I too thought it wouldn’t be good for it!
Old Oct 5, 2020 | 12:23 PM
Unhingd's Avatar
I’m not certain one really needs to wait on it. Just keep the car in a lower gear for a minute or two while driving away, and don’t push it until it’s up to full operating temp.
Old Oct 5, 2020 | 03:56 PM
glenno's Avatar
I think its deliberate to get the cat converters fired up and working.
Old Oct 8, 2020 | 11:07 PM
madmax1911's Avatar
Interesting that there seems to be some variations. Makes me wonder if it is a parameter in the software that can be adjusted?
Thanks for all the responses 👍
Old Oct 9, 2020 | 05:11 AM
takeapieandrun's Avatar
It's definitely an emissions thing and probably can't be adjusted.
I'm thankful for my clutch pedal to manually control load on the engine and quiet it down manually
Old Oct 10, 2020 | 03:27 PM
croco's Avatar
My 2014 XFR takes 60 seconds to drop to normal idle
when cold starts I let it idle for two minutes summer time, and 4 -5 minutes winter time
