Engine ticking sound on start up
Old Aug 29, 2016 | 06:01 PM
IanA's Avatar
Default Engine ticking sound on start up
Hi I have an FTYPE S V6 which has just a 1000 miles on the clock now. When you first do a cold start the engine has a pronounced tick, like a tapper noise which disappears when the engine is warmed up. I wondered if anyone else had experienced this?
Old Aug 29, 2016 | 06:47 PM
Unhingd's Avatar
I had that as well for the duration of the break-in period. Issue faded away entirely by the time I got to 5000 miles otherwise I would have mentioned it at the one year service.
Old Aug 30, 2016 | 01:26 AM
IanA's Avatar
Thanks Unhingd, hoped that would be the case.
Old Aug 30, 2016 | 08:03 AM
SinF's Avatar
I am out of break-in and my car still ticks until I start driving.
Old Aug 30, 2016 | 04:59 PM
Tel's Avatar
Tel
Hydraulic buckets perhaps?
Old Aug 30, 2016 | 07:53 PM
Unhingd's Avatar
Most likely.
Old Oct 28, 2016 | 03:08 PM
Mueller's Avatar
I am having a pronounced ticking noise on start up when cold. Attached is a video of the noise. The noise is not apparent after the car has warmed up. Any thoughts? Should I be rushing this in for service? Does anyone else have this noise?
Old Oct 28, 2016 | 03:43 PM
Unhingd's Avatar
Take it in to be safe. My valve train noise is quite loud until warmup as well, but yours seems to be more uneven.
Old Oct 28, 2016 | 03:47 PM
Mueller's Avatar
I was moving the camera around which had an obvious impact on the volume. I probably will take it in soon.
Old Oct 28, 2016 | 04:07 PM
jbajor's Avatar
mine is identical... 1400 miles
Old Oct 28, 2016 | 04:47 PM
Burt Gummer's Avatar
I accidentally dropped a nut into the carburetor of my '71 Firebird and it started making a noise like that that ended up costing me $4k. So psychologically I wouldn't be able to handle that noise.
Old Oct 28, 2016 | 06:28 PM
Nati's Avatar
My V6 sounds the same. I do not think it's a problem.
Old Oct 28, 2016 | 06:43 PM
jbajor's Avatar
If yours does not go away once engine comes to temp I would be concerned.
Old Oct 29, 2016 | 12:45 PM
Unhingd's Avatar
+1.
Old Oct 29, 2016 | 02:50 PM
Holy F type's Avatar
17,000 kms now and engine ticks while it's warming up then it runs beautifully
Old Oct 30, 2016 | 07:42 PM
IanA's Avatar
My ticking sound has all but faded away at 3500 miles.
Old Oct 31, 2016 | 01:27 PM
Kitesurfer's Avatar
Yikes that's some chatter. I'd be curious to see what Jag service says about it. My 2014 V8 is quiet at startup.
Old Oct 31, 2016 | 06:56 PM
TwiztOG43's Avatar
Mine still ticks when cold for a couple minutes, goes away when its warmed up. Currently around 15k and just had the car serviced 2 weeks ago.
Old Nov 1, 2016 | 01:47 PM
F-typical's Avatar
That sounds more like something to do with the belt driven bits on the outside of the engine - based on the frequency.
Old Sep 5, 2017 | 04:29 AM
kaspa's Avatar
old thread alert ..... sorry
I have this issue on my 2018 F Type coupe .. car has completed 1200 miles, do I need to worry ? or is this normal so just wondered if there are some engine experts on this site to put my mind at rest
all the best
