Engine tune dealer service question
Old Aug 26, 2024 | 02:53 PM
TrialByError's Avatar
Default Engine tune dealer service question
My 2014 V8s has a parking brake fault warning. Not a voltage problem and no obvious wire issue so might have to go to the dealer. Do you guys with tunes revert back to stock or is it not a problem for a tune when modules might need replacing?
Old Aug 26, 2024 | 06:21 PM
uncheel's Avatar
Don't worry about it. Some owners are very cautious, especially if they're still in the warranty period, but you're well beyond that.
As a side note, a dealer - could - figure out the system has been modified, even if you revert. They just won't (and don't really care if you have an unrelated issue).
Old Aug 26, 2024 | 06:48 PM
ftype_rick's Avatar
I would put a locking cover on the OBD port so they can’t hit you with an updated stock flash. They did this to my car when I had it in for cat replacement (covered under warranty). The result was a locked ECU that needed the $100 VAP unlock credit and then a reflash…was quite annoying.
Old Aug 26, 2024 | 08:29 PM
JgaXkr's Avatar
How will they be able to plug in a diagnostic computer?
Old Aug 26, 2024 | 08:59 PM
ftype_rick's Avatar
If they need access to the OBD to complete service, then just make it very clear you don’t want them touching the tune (make sure it’s written in your maintenance file). You don’t have to specify that you have an aftermarket tune, just that you like the existing the way it is.
LCF-TpyeR
Jun 21, 2024 10:09 AM
FullChat
Jul 20, 2021 10:17 PM
santacruz11
Apr 30, 2021 07:58 PM
El Gato
Jan 7, 2021 09:56 PM
XxMerlinxX
Sep 2, 2017 09:48 PM
