Exhaust valve actuators
Old Jan 9, 2021 | 09:21 PM
malbec's Avatar
Default Exhaust valve actuators
My active exhaust no longer functions.
Got dealer to check and they said it was the actuators.
They are not covered by warranty since it’s exhaust. However I’m wondering if they are not part of the box and so should be covered.
What is are these exactly?
Old Jan 9, 2021 | 10:34 PM
Unhingd's Avatar
The exhaust valves/actuators are integral to the muffler. If they go bad, the whole OEM muffler needs to be replaced. (The advantage of a VAP muffler, is that the valves can be replaced). Here in the U.S., the warranty covers the muffler. I don't see why it wouldn't be covered in the U.K.
Old Jan 10, 2021 | 05:25 AM
malbec's Avatar
Thanks Lance.
I’m not bothered about the sound. Just that I paid a lot of money for extended warranty and would like to get my money’s worth. They won’t pay!
Old Jan 10, 2021 | 06:50 AM
Unhingd's Avatar
Thanks Lance.
I get it. I thought you were still on the OEM warranty. Even here in the U.S., the extended warranties generally don’t cover anything related to the exhaust system.
Old Jan 10, 2021 | 01:08 PM
ferrral's Avatar
I'd check for a vacuum leak. There are vacuum pots on both sides of the muffler. I'd be surprised if both of them failed at the same time.
Old Jan 10, 2021 | 01:50 PM
malbec's Avatar
Thanks but the mechanic said that the things in the photo were broken. I think he meant that the straight bit was supposed to be attached to the other bit.
I tried to post a video but although it’s the right size it won’t play for me on the forum.
File Type: mov
Old Jan 10, 2021 | 02:09 PM
DJS's Avatar
DJS
I was able to play your 4s video. I had forgotten there’s a linkage connecting the vacuum actuator to the valve shaft. If warranty doesn’t cover a new muffler, I’d try drilling it and using some kind of fastener to hold them together. It’s pushing against a strong spring, so it would need to handle decent torque. And heat.
Old Jan 10, 2021 | 02:32 PM
malbec's Avatar
Thanks for your reply. In the video which is the actuator and which is the valve shaft?
Unhingd's Avatar
An Indy muffler shop should be able to tack weld that back together.
Old Jan 10, 2021 | 03:38 PM
ferrral's Avatar
Ah, sorry, got it. I had an issue with the valves squeaking and had to replace the whole unit. JLR sent me 3 mufflers because the actuators kept getting damaged in shipment and as you know there is no way to replace them as a single component.
Old Jan 10, 2021 | 11:29 PM
DJS's Avatar
DJS
Except the joint has to pivot.
https://www.dropbox.com/s/szc3vze5ol...haust.pdf?dl=0
Old Jan 11, 2021 | 09:57 AM
Unhingd's Avatar
I just looked at my OEM muffler to see the detail, and you are correct. However, a competent shade tree mechanic should be able to fix it with a drill and tiny pivot bolt. Time to pull that muffler off and get to work on it.
Old Jan 11, 2021 | 10:25 AM
malbec's Avatar
Yes I guess there’s a diy solution but I stopped working on my cars 50 years ago. That diagram posted by DJS has enabled me to understand how it works and what has failed. I’ll wait a few years until the muffler needs changing. Pity the warranty doesn’t cover it but I’m too old to care about changing the exhaust sound. Looking at the diagram and the mechanic’s video I think the valves are stuck open but I can’t tell since I can’t change the noise.
Old Jan 11, 2021 | 12:42 PM
Unhingd's Avatar
With a bit of baling wire you could have someone wire the broken valve permanently in the open position.
enderle
Mar 8, 2020 03:26 PM
StormtrooperFtype
Dec 22, 2019 05:20 PM
mushroom09
Sep 3, 2019 05:19 PM
Jfry61
Aug 14, 2017 10:19 PM
Mad Matt
Jul 5, 2014 09:03 AM
