F-Pace front Grill for F-Type
Old Apr 14, 2024 | 11:38 AM
Laika's Avatar
Default F-Pace front Grill for F-Type
I have a 2015 F-Type R. I do not care for the split front grill with the push bar and would like to change to the P-7 front grill look. I see many aftermarkets that are sold but the quality is questionable.
Question: Will an OEM F-Pace front grill work as a replacement for my F-Type grill? If it can, would I need the same year or can that very a bit?
thanks in advance,
Old Apr 15, 2024 | 10:39 AM
skizot's Avatar
@Laika I would suggest doing some searching on these forums, this topic has been discussed at great length, including all the options. The short answer however is yes you can pair an aftermarket CF surround you could purchase from ebay or aliexpress with an e-pace mesh grill, with some modification to create a P7 style replacement grill. 2019-2014 all use the same basic grill structure. Hit that search button, there are a TON of threads on this, that will walk you through, step by step.
Old Apr 15, 2024 | 11:40 AM
BigJay13's Avatar
@Laika Reading through the forum will show you many different ways to do the modification. However, because you mentioned the e-pace grill I will stick to just this one. The e-pace grill has to be cut and fitted to your existing framework and this is all by you. In addition, the parking sensors have to be fitted and you will need to reattach two clips at the top of the grill which I can't remember what they are called right this second. And the final thing, don't forget to buy a new surround. The current one you have has 2 indentations for the crash bar and those are not on the project 7 grill. I wish you luck with this.. I am about to try another route of doing this myself, so if I figure it out, i'll let you know.
Old Apr 15, 2024 | 12:22 PM
eeeeek's Avatar
The E-Pace grill can be adapted with a little trimming/drilling and a new surround.
Old Apr 15, 2024 | 06:34 PM
Laika's Avatar
Thanks got the help and ideas. Let me see what I can find to do the change.
Old Apr 15, 2024 | 06:36 PM
Laika's Avatar
Thanks for the help and ideas. BigJ13, would be interested in your solution/idea.
Old Apr 17, 2024 | 05:48 AM
genp729's Avatar
See -->
Old Oct 8, 2024 | 11:27 PM
Magnito1's Avatar
Default It will fit
thanks in advance,
It fits
Old Oct 9, 2024 | 01:13 AM
eeeeek's Avatar
Originally Posted by Magnito1
It fits
As mentioned earlier, the E-Pace grill will fit with some minor modifications, not the F-Pace.
Laika
Jan 6, 2025 07:01 AM
tec-9-7
Nov 22, 2022 12:12 PM
ubsvr17
Nov 8, 2022 02:52 PM
powerhouse
Nov 14, 2019 07:01 PM
JgaXkr
Aug 6, 2017 11:17 AM
