F-Type R more camber
Old Oct 8, 2021 | 03:32 PM
davidchentl's Avatar
Default F-Type R more camber
Hi! I own a 2016 R and track the car occasionally. I found the factory max front camber of around -1.5' does not help at all with excessive tire sidewall wear. Does anyone have any recommendations about any aftermarket resources for suspension tuning? Thanks!
Old Oct 8, 2021 | 07:42 PM
Unhingd's Avatar
Yes...lower the suspension. The H&R Springs will allow you to adjust out to almost -3.0 drgrees. The lower center of gravity will also serve to significantly reduce body roll.Additionally, your tire pressure may be too low for roadtrack conditions.
Old Oct 9, 2021 | 08:50 PM
Thank you! I will give it a try.
Old Jun 5, 2023 | 04:13 PM
MX-Moose's Avatar
Hey @davidchentl , I was curious if you ever gave the H&R springs and additional track days a try to see what you found! I just did a track day and destroyed the outer edge of my tires on my Continental ECSs. Definitely needs more camber!
fstik
Feb 14, 2021 08:13 AM
OzXFR
Apr 11, 2020 07:56 AM
jlsthlm
Apr 1, 2020 09:16 PM
Jhereg
Dec 11, 2018 12:25 PM
Breaker841
Aug 17, 2016 08:57 PM
