F-TYPE SVR not sitting flat!
Old Oct 20, 2020 | 08:50 AM
MK45's Avatar
Default F-TYPE SVR not sitting flat!
Hello All,
I have a very curious thing going on: my F-Type SVR isn’t flat! I was mounting new wheels and noticed a sizable wheel gap, and decided to check the other side with the OEM wheel to see if I’m crazy or if it’s the same. Well it wasn’t the same, so I put back on the OE rims on both sides of the car and.... it still wasn’t the same? Nothing heavy is In the car, and me sitting in the car makes no difference as the height delta is enormous I’ve attached photos as a quick visual way of demonstrating the difference in wheel gap.
The measurements are:
Drivers side rear: 6.4cm
Passenger rear: 4.6cm
Any idea what would be causing this?
Old Oct 20, 2020 | 10:46 AM
Rummy636's Avatar
What are the measurements from the front? An issue with the front diagonal side can cause an uneven ride height.
Old Oct 20, 2020 | 12:45 PM
MK45's Avatar
front drivers side: 3.1cm
front passenger side: 2.4cm
Old Oct 20, 2020 | 04:06 PM
Phil Edwards's Avatar
How long did you leave it before measuring it, did you drive it around and the measure again ? They always look high after you jack them up until the settle even more so when you jack one side at a time.
Old Oct 20, 2020 | 09:10 PM
supersportmtl's Avatar
First question...sorry I’ve got to ask... is anything stuck under one side of the car.. did you leave anything under there after the wheel install ?
Anything left or got stuck in the suspension coil spring of the “high side” ?
Other than that I have no clue as to why this is happening. Have never seen this ...
Old Oct 20, 2020 | 09:17 PM
OzXFR's Avatar
This!
Take it for a decent spin then remeasure.
Old Oct 21, 2020 | 07:50 PM
Unhingd's Avatar
If that doesn’t resolve it, perhaps one of the rubber spring seats is not positioned properly.
MK45
Oct 10, 2020 11:42 PM
camstang6907
Aug 14, 2020 06:52 PM
Johnny Mayday
Nov 2, 2017 05:12 PM
Jaguar Forums Editor
Aug 19, 2016 03:54 PM
Dremorg
Jun 22, 2016 09:51 PM
