False Positive Warnings With Parking Aid System
Old Sep 20, 2021 | 09:11 AM
Dwight Frye's Avatar
Default False Positive Warnings With Parking Aid System
A few days ago I got off the freeway and was sitting behind a Dodge Challenger waiting for the light to change. He had what was probably an aftermarket exhaust system that was quite loud. neither of us were moving and I was several feet behind him. All of a sudden my Parking Aid warning system started beeping and then went into a solid beep tone like I was about to collide with an object. When the light changed and he pulled away it stopped.
I was thinking that perhaps the exhaust pulses from his car somehow triggered the parking sensors. But the next day in a similar scenario, I had just gotten off the freeway and the warning system went off, this time showing a collision threat to both the front and the side of the car, and there was another car next to me on the left but it was a comfortable and normal distance away. Once we started moving the warning stopped.
The owners manual says "If a parking aid system fault is detected, a long, high-pitched tone sounds and the parking aid icon flashes. The touchscreen displays a parking aid warning message. If all of the sensors are clean and, after restarting the engine, the issue persists, contact a retailer/authorized repairer as soon as possible." I don't remember if the icon was flashing, and the sensors are all spotless.
Has anyone else had this happen ? I guess if it becomes a regular occurrence a trip to the dealer will be in order. It certainly startled me when I wasn't expecting it like when I am pulling into my garage or up to a parking space concrete bumper and it goes off so I don't scrape the spoiler.
Old Sep 20, 2021 | 10:55 AM
Thunder Dump's Avatar
I've had it happen at a light. It doesn't always do it, but if you're close enough to the car in front of you and you're stopped it thinks you're trying to park and activates the sensors.
Old Sep 20, 2021 | 08:00 PM
Valerie Stabenow's Avatar
I have a MY2017 Coupe that started doing this in the last month, at 31k miles. It's only the right front that's acting up. It starts when I back out of the garage and if I am a bit too close to the right side of the garage door, it goes off like it should. However , it then won't shut off, despite being 20 feet out of the garage. Left side doesn't do it. I talked to my JLR service advisor and she noted that she's had several instances of this, so I have an appt. in a couple of weeks for them to sort it out, and that it should be covered under warranty. Will report back as to resolution.
Old Sep 21, 2021 | 09:29 AM
uncheel's Avatar
I had a similar experience with the F-Pace (no parking assist on the F-Type). Dealer replaced the right front sensor on my next visit and the problem went away.
WookieRuss
Jul 3, 2020 06:07 PM
JayPHunt
Oct 3, 2018 02:33 PM
Jon Robinson
Feb 8, 2017 07:12 AM
LobsterClaws
Jan 6, 2016 09:22 AM
Bkny85
Feb 19, 2014 09:43 PM
