Front strut brace ...
Old Jan 15, 2017 | 07:08 PM
Ubad2's Avatar
Banned
Default Front strut brace ...
Hi guys, I see that many high performance sports cars have a front strut brace to improve the suspension handling. Is the brace actually a cosmetic gimmick or does it actually benefit the handling of the car. I'm wondering why the F Type doesn't have a strut brace. Your message thoughts please. Thanks.
Old Jan 15, 2017 | 07:24 PM
Stohlen's Avatar
In some respects it helps performance, but it certainly depends on how rigid the chassis is. Based on what I know about chassis design, my assumption is there wasn't significant enough clearance to fit one between the strut towers and the hood; and likely the chassis is stiff enough that the engineers didn't want to mess everything up just to add one.
Old Jan 15, 2017 | 07:39 PM
OzXFR's Avatar
Look under the hood, the F-Type already has four braces, all of which are bolted to the strut tower area. So in effect it already has a "front strut brace", it's just in four pieces and it runs front to back rather than side to side.
Old Jan 15, 2017 | 07:47 PM
Cambo's Avatar
Do you really think that the F-Type chassis is not stiff enough?
The convertible is already 10% stiffer laterally than the XKR-S Coupe, and the suspension mounting rigidity in particular is noted to be 30% stiffer than the XKR-S.
And then the F-Type Coupe is noted to be 80% stiffer than the Convertible...
Numerous road tests and reviews of the Convertible when it was first released saw comments like "it shows no scuttle shake or flexing at all"
I don't think anyone ever complained about the chassis not being stiff enough... especially a Coupe...
Old Jan 15, 2017 | 07:59 PM
Unhingd's Avatar
+1. Other than a couple of birdcage frame cars I've had, this is the first where I have sensed absolutely no chassis flex.
Old Jan 16, 2017 | 02:26 PM
DPelletier's Avatar
strut brace is a bandaid for a flexy chassis......not needed on the F type.
Dave
