Fuse 15 -> Check Engine Light?
Greetings all,
A few weeks ago I removed fuse 15 in my ‘21 R, no regrets. However today as I was making my way to the Tail of the Dragon (about a 500 mile trip) I saw an amber check engine light illuminate. I got into the manual and it said this: “The lamp remains illuminated until the engine starts. If the lamp illuminates when the engine is running, an emissions-related fault has been detected. The vehicle remains safe to drive with the lamp illuminated, although qualified assistance should be sought as soon as possible.”
Has anyone else had any emissions faults related to pulling the fuse?
Greetings all,
Perhaps a failed oxygen sensor? I keep hearing that these like to go. I can’t imagine the fuse 15 pull is a direct cause.
You don’t have a code reader? I still need to get one myself.
High unlikely, Fuse 15 is for active exhaust flaps and should have nothing to do with the engine. I've had the fuse out for over 2 months with no warnings, others on here have had the fuse out for years. Maybe one of your sensors failed?
That’s what I was thinking. The flaps should have nothing to do with o2 sensors. Welp back to the dealer I go. I’ll let you guys know what’s going on once I finish my weekend trip. (Definitely still attacking Tail of The Dragon full send)
Not surprised!!
I always suspected that problems with cats and O2 sensors might be related to excess unburned fuel.
I did run for while with the fuse removed (now replaced) but figured it probably increased the risk of cat damage.
A bit surprised if it happened on a 3 year old car. How many miles??
I haven't tried pulling the fuse, but my understanding is that it only affects the valves in the muffler. If that is the case, I don't see how it could possibly cause a CEL, or MIL if you prefer to call it that.
The excess unburned fuel is from the programming to cause "pops and crackles" to mimic the sounds from carbureted engines. Sure, it sounds cool, but there is no benefit whatsoever other than the cool sound.
Since the valves are located in the last 2' (in the V6) and last 1' (in the V8) of the exhaust pipes, pulling fuse 15 does not and will not cause a CEL. It can't. The valves are not part of the emissions system--they are for noise abatement purposes only. Additionally, the position of the valves has nothing to do with *creating* the pops and bangs with fuel overrun. That is an ECU programming that is dependent on drive mode. It just so happens that some of those drive modes have the valves open as well and so you hear them better.
I've run without the fuse on two separate F-Types for over three years without an issue on either. I've also gone through annual CARB-state emissions system testing and passed without issue each time with the fuse removed during testing.
I am certainly no expert, but the pops and bangs arise from burning off excess fuel.
Opening the exhaust valves reduces back pressure on the exhaust system.
Does that enable more fuel to enter the cats? I do not know.
But, it is a fact that excess fuel in the exhaust will kill the cats (and the O2 sensors?).
https://www.cars.com/articles/what-a...1420663031608/
I haven’t heard of or seen any of the newer cars suffering from O2 sensor failure so this was unexpected. On a (maybe?) related note, during my mountain carving I briefly got “suspension fault” and “E-Diff unavailable, traction limited, 2 wheel drive only” faults. I freaked out. Pulled the car over and cycled power after a few minutes, the warnings disappeared and after an hour or so proceeded to drive at 9/10ths since about 9 this morning. Maybe an electrical gremlin? Thoughts?
I just had my coolant pipes updated and a week later the check engine light came on with the P013E code for O2 sensor failure. The dealer said not related and the sensors are under warranty and they will replace no charge.
what year is your car?
Did the problem come back at all? One thing is for sure, I think having a code reader is basically mandatory with any of these types of complicated vehicles…Not limited to Jag I don’t think…
Gosh, I don’t know. I’m new to F-types and my car is brand new so I have very few miles on it.
