Green Coolant
Old Nov 5, 2023 | 10:17 AM
eclipse641's Avatar
Default Green Coolant
Hello everyone,
So today I went to check my coolant level to find out it was green in color. I see on many threads it requires orange coolant wss M97B44. I have only had the car for about 2 months and driven 300 plus miles. I also had an indy check out the car a few weeks ago and there were no leaks etc. Should I have the coolant flushed to the correct color or is this not of any concern?
Thanks in advance!
Old Nov 5, 2023 | 12:13 PM
clubairth1's Avatar
Community Influencer
Yes the green is wrong. The car uses Dex-Cool and that's what I would put back in.
Now I hope who ever made the bad decision to swap to green did a THROUGH flush otherwise your going to find gelled up coolant!
But it's your car so you decide.
Old Nov 6, 2023 | 08:27 AM
Dwight Frye's Avatar
Pentosin Pentofrost SF is an approved coolant. I would do as clubairth1 suggests above and replace the green coolant pronto. And probably flush the system first. I found some of the Pentosin Pentofrost SF locally at O'Reilly Auto Parts but it can be ordered online from several sources. If you go to a place like O'Reilly's they often put it on the shelf with 1 quart oil bottles since it doesn't come in a conventional gallon jug..
It seems expensive for a 1.5 liter bottle but it needs to be diluted 50/50 with distilled water. Here's one source:
https://www.fcpeuro.com/products/sf-...012a8fa4-15l-1
Old Nov 6, 2023 | 08:47 AM
eclipse641's Avatar
So upon further investigation I did read that orange coolant can look neon green at times. I did take some out of the reservoir and it is in fact orange and not green.
Old Nov 7, 2023 | 11:23 AM
clubairth1's Avatar
Very true and good to hear!
Sounds like you have the correct coolant.
Old Nov 8, 2023 | 03:50 PM
eclipse641's Avatar
Thank you to all for taking the time to reply! Much appreciated! 💯
TheRealMoleman
Jan 16, 2020 04:21 AM
Ordhyait
Mar 29, 2019 10:39 PM
johns427
Apr 23, 2016 11:05 AM
David7
Nov 30, 2015 10:24 AM
hankycbr
Oct 9, 2007 04:21 AM
