Group Buy: (4) 17mm hubcentric adapters/spacers
Old May 2, 2017 | 11:00 AM
  #321
Mpowerr's Avatar
Originally Posted by Unhingd
There is no difference between the R and SVR rear fenders and hubs, so the rear clearances are the same. However, (someone please correct me if I'm wrong) the SVR wears 305 rear shoes. Even 15mm spacers will be too much if you plan on lowering the car.
Correct, and the rear wheel is an 11 as opposed to 10.5.
Old May 2, 2017 | 12:46 PM
  #322
zmoothg's Avatar
The SVR wears 305 rears but the offset is more positive (less negative) on the Maelstrom wheel, which results in the wheel actually moving slightly inward, which might allow for a slightly wider spacer. Next week, I will pull off my rears and get the exact offset.
Old May 2, 2017 | 02:07 PM
  #323
Unhingd's Avatar
Originally Posted by Dan's cat
Has anyone ever gone more than 17mm in the rear? Looks like there is more room, but I don't want the tire to stick out past the top of the quarter panel.
There is not. Might work for awhile, but will tear up your fend if you hit a deep pothole.
Old May 4, 2017 | 12:06 PM
  #324
Burt Gummer's Avatar
My precision torque wrench set at 92lbs confirmed that my other cheap one was not really torqued to 92 and now things are all better in spacer land.
Old May 4, 2017 | 01:20 PM
  #325
DJS's Avatar
DJS
Keep in mind the torque needed to break loose the nut for removal wouldn't be the same as the torque used to tighten it.
Old May 4, 2017 | 01:55 PM
  #326
Yep. With the precision wrench at 92lbs I got a full 1.5 turns on everything. I went cheap tool wise, won't be making that mistake again. Now everything is butter smooth vibration/sound wise and she feels like a missile going down the highway. Happy camper.
Old May 4, 2018 | 08:06 AM
  #327
Prophizee's Avatar
So I just ordered my spacers, 17mm all around. Was wondering I have gyrodyne wheels do I need to trim the studs at all or is it a direct fit thanks
Old Aug 11, 2018 | 08:06 PM
  #328
Jaggyx's Avatar
About to pull trigger on 17MM all around. Just want to verify that there shouldn't be any rubbing with a mild drop (Eibach lowering Springs).
Edit: Might go 15MM to play it safe.
Old Aug 12, 2018 | 04:07 AM
  #329
Unhingd's Avatar
My experience: 15mm with 295s on back works well regardless of the drop. Increase the tires to 305 and you'll catch a fender lip.
Old Aug 12, 2018 | 04:28 AM
  #330
Gyrodynes. 17mm. Yes you must grind but BFD -- fast, easy, simple.
Old Aug 12, 2018 | 11:59 AM
  #331
Jaggyx's Avatar
15MM it is then - thanks.
Old Aug 13, 2018 | 09:44 AM
  #332
WJV's Avatar
WJV
Originally Posted by polarisnavyxj
Calling all new F-Type owners...
OK guys I just called Lenny down at Motorsport Tech, the guys who did the GB for the elder members (40 units) and we are going to do a round two.
The advantage now is the adapter will be at 17mm which now PREVENTS THE NEED TO DO ANY CUTTING OF YOUR STUD!
This is huge as it will save us time and money. These are now a true DYI without the needed in involvement of expensive wheel companies or machine shops. No grinding at home.
I was quoted $245 shipped for one set but was told that we would all get $50 off if we can get 10 or more people involved.
Delivery will be within a week!
Please express your interest here, in this post.
I will post before and after pictures so you can see the difference!
Want to thank VIC55 for his original post that offered his advice and pics from round one.
Interested in a set of these. Take my money! Where do I buy?
*These will fit a Coupe with the 63.4mm center bore, correct?
Old Aug 13, 2018 | 10:17 AM
  #333
Greggbhill's Avatar
Call Lenny - mention jag forum for discount
Motorsport Tech
280 S Rock Blvd, Ste 100
Reno, Nevada 89502
(775) 351-1000 - Voice
Old Aug 13, 2018 | 11:05 AM
  #334
Itismejoshy's Avatar
before i call Lenny, anyone know the stud used on the adapter? i need one due to an unfortunate tire/wheel event.
Old Aug 13, 2018 | 12:50 PM
  #335
WJV's Avatar
WJV
Motorsport Tech
Reno, Nevada 89502
Thank you! Just placed my order
Old Aug 13, 2018 | 01:16 PM
  #336
Unhingd's Avatar
Just call Lenny. He'll be able to send you the exact stud that you can have pressed into the adaptor at a local shop.
Old Aug 13, 2018 | 07:25 PM
  #337
OzXFR's Avatar
No need to go to a shop to have the stud pressed in as long as you have an open nut of the right size.
I have replaced two broken spacer studs now, and the replacement studs I bought from a local auto parts store (Repco) came with 22 mm open nuts.
Once I removed the broken stud I inserted the new stud, hammered it in just a little to get it to grip then simply pulled it in tight using the 22 mm nut, then removed the nut.
Of course it helps to have a workbench vice to do this!
Old Aug 13, 2018 | 07:57 PM
  #338
vettegood's Avatar
Hello,
I have two brand new 17mm spacers in anodized black with mounting nuts included.
if anyone bought 15mm and wants a bit wider in the rear.
These are new from motorsports in Vegas never been used or mounted. 75.00 plus shipping
85086 zip
Old Aug 16, 2018 | 03:19 PM
  #339
Jaggyx's Avatar
Just installed my 15MM spacers in the front. Is anyone experiencing a bit of force fitting the wheel onto the spacer hub? My wheels don't mount on the spacer hub without having to be pursueded by tightening the lugnuts.
Also, the rear factory studs need to be trimmed more than they do in the front with Tornado wheels. Tried to bolt up the rears as well and there was a very noticeable gap.
Old Aug 16, 2018 | 09:59 PM
  #340
Unhingd's Avatar
The hub-centrics on Jag wheels varies between 63.3 mm and 63.4 and the adapters are 63.4, so with some wheels there will be a 0.1mm interference fit. This is not an issue, but does require a bit of effort the first time you try to remove a wheel. After that, it gets easier.
