Group Buy: (4) 17mm hubcentric adapters/spacers
Old Jun 4, 2020 | 07:19 PM
  #361
Unhingd's Avatar
Originally Posted by dsprague27
Also, follow up question; has anyone staggered the spacer sizes? Wondering if 17mm front and 19mm rear would work. If possible, would the 19mm require any modification to fit appropriately?
17mm is the absolute maximum you can go on the rear without scoring the tire or creasing your fender lip when you hit a bump or pothole.
Design 3 is correct and no additional hardware needed.
Old Jun 8, 2020 | 01:16 AM
  #362
hwa23's Avatar
Appreciate if anyone could point me to the right lug nuts that comes with the motorsport tech spacers - Wheel Adapters, Wheel Spacers, Hub Rings, and much more! | Motorsport Tech
I was given wrong lugs which would not fit on the studs so I procured them locally. But as mentioned on another thread, there's some clicking noise while turning which happens when it gets hot (after some driving). Not sure if it might be the locally procured lug nuts. I've checked, the tyres are not making contact with anything while fully turned.
Old Jun 8, 2020 | 01:37 AM
  #363
OzXFR's Avatar
You want the 12x1.5 open end conical.
That is if the spacers are like every other set I have ever known!
watson6505
Jul 6, 2020 04:09 PM
Dabitz
F-Pace (X761) / C-X17
Jan 15, 2018 08:33 AM
watson6505
Jan 15, 2018 08:28 AM
watson6505
XF (X260)
Jan 15, 2018 08:27 AM
BC XJS
Aug 9, 2017 07:12 PM
