Highest coolant temperature you’ve seen?
Old Mar 23, 2025 | 09:50 AM
SportsEngineer's Avatar
Default Highest coolant temperature you’ve seen?
I have the Torque app installed, and I monitor the coolant and oil temperatures (and a few others) realtime while driving.
The highest I’ve seen my coolant temp go up to is about 103 Celsius (aggressively driving uphill on some twisty roads).
Whats the highest you’ve seen on your car for coolant temp?
Old Mar 23, 2025 | 02:08 PM
Craaaazzy's Avatar
Copy/paste from one of my posts:
The highest I saw the oil temp was 232 degrees F and coolant temp was 212F. This was with ambient temps in the mid 60’s and me pushing the car between 90-95%.”
Old Mar 23, 2025 | 06:52 PM
RGPV6S's Avatar
100 C Coolant and 100 C oil temp. Coolant cycles between 96 C to 100 C throughout a spirited drive. Oil temp takes at least 20 minutes to catch up to coolant temp and is fairly stable once peak is reached.
Readings are from the Torque app.
Old Mar 24, 2025 | 09:20 PM
JagCode3's Avatar
Like @Craaaazzy - 230 F (110 C) on a cool day going slow in town, lots of stops and starts at low speed.
I was close to pulling over if it went any higher and pop the hood to look for leaks. Don't want to lose the engine because of a brittle plastic pipe!
I have the coolant at max level now and the highest I get now is 220 F (104 C) , which is rare. That is where I set my first Torque visual alert. Sound alert is set to 230 F.
Gasman2
Jul 10, 2023 10:07 AM
Clackavosticus
Nov 24, 2021 06:16 PM
Daniel Thomas Eakin
Nov 16, 2018 05:08 PM
Farid
Sep 9, 2018 01:54 PM
jagtoes
May 9, 2016 08:00 PM
