Hot start Issue
Old Jun 7, 2023 | 09:04 PM
randyb's Avatar
Question Hot start Issue
Owned my cars two days, this has happened twice.
Go to store and come out, press start after pressing brake and get a click; wait 10 seconds and try again and it starts. Day two ditto, no issue when starting cold and everything else is fine; so is there an issue with the starting system, cannot seem to find a TSB about starting issues.
Old Jun 7, 2023 | 09:33 PM
Borbor's Avatar
battery issues 99% of the time. read one of the 50 threads about it ,causes of possible battery drain, battery reset procedure and how to trickle charge
Old Jun 7, 2023 | 10:14 PM
randyb's Avatar
This is not a battery issue, volts is almost 13. Had the same issue with my XK, was trying to track it down when the car got totaled. I think it is a heat soak issue somewhere in the starter/ solenoid or somewhere in the system.
Old Jun 8, 2023 | 08:01 AM
clubairth1's Avatar
Community Influencer
Just a guess? When this happens again push harder on the brake pedal.
Also when it does not start are the brake lights coming on?
We have seen multiple times that the brake switch is a bit out of place and is not getting pushed in properly.
Old Jun 8, 2023 | 09:12 PM
randyb's Avatar
@clubairth1 Thanks, I will check the lights and the brake switch!
yvonjaguar
Jun 9, 2022 10:42 AM
ratgawd
Dec 27, 2014 12:21 PM
strokez
Mar 11, 2014 01:16 AM
dwiniarz
XJ40 ( XJ81 )
17
Mar 28, 2013 11:14 PM
robin mayor
Dec 17, 2009 07:45 AM
