How do I access the set up menu
Old Apr 24, 2017 | 06:01 PM
Ali Shiralian's Avatar
Default How do I access the set up menu
Hey guys I've had the car for five days now and today I finely had an hour to sit in the car and play with the nav and music etc..
The question I have is while I was at the dealership, someone was explaining all the stuff to me but I guess I wasn't paying enough attention or was too excited to drive the car but anyways I swear he brought up the menu which had to do with global settings such as lighting, doors and etc.. how do I access this again or is it only a dealer thing and once they set it up you can't have access to it anymore?
Also I played with the camer settings a bit and check marked the lines and the little square thingies but lost the beeping sound along the way. Now the car is silent as I approach a curb with the parking assist on which sucks and kinda frightening.
Any help would be appreciated. I come from a BMW and the I Drive was so user intuitive but the car itself was never as much fun.
Cheers...
Old Apr 24, 2017 | 06:06 PM
JagAlb's Avatar
Welcome to the Jaguar. The lots of fun come at a cost of ancient infotainment or driver interface. You should shut off the engine and then navigate through the required menu. Especially for oil check you need to keep the engine off and car leveled in order to measure right.
Old Apr 24, 2017 | 06:15 PM
Ok I just did what you said but nothing came up. Pressed the menu bottom on the steering wheel and the only thing that comes up is the trip adjustment nothing else.
Old Apr 24, 2017 | 06:21 PM
stmcknig's Avatar
Try the little gear wheel icon in the bottom left of the button set on the infotainment cluster...
Old Apr 24, 2017 | 06:22 PM
OzXFR's Avatar
Usually I have to press the Menu button a few times before the menu pops up (in the screen between the speedo and the tacho).
Old Apr 24, 2017 | 06:35 PM
Ok thanks I haven't tried to hit it more than once, I'll try pushing it repeatedly to get to the other menu
Old Apr 24, 2017 | 07:42 PM
Unhingd's Avatar
With the ignition on (engine off), press the menu button, then use the up/down arrows to get to submenus. Once in the right submenu, scroll right arrow to see options. To exit out of menu press the left arrow enough times to back out of all the levels. The oil level will not show anything if the engine has bee run in the last 10-15 minutes.
Old Apr 24, 2017 | 08:28 PM
I've done exactly that Unhinged but the only thing that comes up is the trip computer and nothing else. I'll try pressing it a few times tomorrow to see if anything else comes up. I may have to read the dreaded manual
