How do I disable auto start/stop?
Old Apr 24, 2015 | 12:41 PM
  #61
BierNut's Avatar
Originally Posted by rhutch98
Does your car have Configurable Dynamics?
I plan on bring this up when I go in for a service but for sure I can confirm for my car eco stays on in dynamic mode. I can also confirm, based on my ride in to work, that although the eco button stays lit when in dynamic and manual mode it does not turnoff the engine when stopped. However when I took the car out of manual mode by holding the paddle the engine shut off.
My 2015 V6S does not have configurable dynamics, is a CA car, and eco mode is shut off when the car is put in Dynamic.
As others have pointed out, your car seems to be functioning differently, and it is probably worth having the dealer check it out.
Old Apr 25, 2015 | 11:36 AM
  #62
johney5's Avatar
I have a 2015 coupe.. v6 standard. my eco stays on in sport mode. i disconnected the little battery, seems like that does it... no big deal. Its so easy to do, i cannot see why you wouldn't try it... i freak out every time i come to a stop and have the impression the car is stalled.
Old Apr 28, 2015 | 05:50 PM
  #63
TXJagR's Avatar
When I took delivery of my car, my salesperson was going through the features, and when he came to the "Eco mode" button, I told him I would ALWAYS be pushing the button to disable it. He told me, "I can't officially tell you that we reccommend this, but I have spoken to our techs, and it seems like almost everyone disconnects the second battery and simply tapes up the leads. He told me that he has confirmed this will do NOTHING to the vehicle other than disable the Eco feature. (off the record of course...)
Old Apr 28, 2015 | 07:36 PM
  #64
LynxFX's Avatar
Would unhooking the second smaller battery and leaving it cause it to discharge or harm it in anyway? Also, would you be able to jumpstart the main battery in an emergency? Might be useful vs just removing it all together.
Old Apr 28, 2015 | 07:42 PM
  #65
TXJagR's Avatar
The smaller battery wouldn't be good for "jumpstarting the main battery"
I had no intention of removing the battery, just simply disconnecting it (and making sure I tape up the leads that were disconnected.
Old Apr 28, 2015 | 08:07 PM
  #66
Mulmur's Avatar
The master mechanic at my dealer said to just take the negative off the small battery and tape it... nothing else needs to be done...
The main battery is unaffected.
Lawrence
Old Apr 29, 2015 | 02:56 AM
  #67
Trance raver's Avatar
I have had my small battery disconnected for seven months now, my car runs fine with no malfunctions.
If you don't like the stop start disconnect battery. Simples
Old Apr 29, 2015 | 04:18 AM
  #68
Tel's Avatar
Tel
It's ON unless you switch to off manually on the new MY16 cars.
Also in the new models there is no second battery (also mentioned by others), just a 'module' which I guess helps shed some extra weight.
It matters not, which mode you are in.
Old Apr 29, 2015 | 06:56 AM
  #69
Foosh's Avatar
Even on the '14-'15 models, the eco mode light on the button may be on, but the engine often does not shut down at a stop when operating in certain ways. That is the case when you put the shifter in sport mode or paddle a down shift in automatic before a stop. Only selecting dynamic mode or pushing the eco button shuts the light off.
The only time my '14 shuts down at a stop is when I'm in automatic, non-dynamic, and I have not paddled a down-shift just before stopping. In other words, having the eco mode light on does not mean the engine is going to shut down at a full stop.
Once you've had a chance to play with your '16, I'd be interested in hearing if the same is true on 16s.
Old May 6, 2015 | 06:22 AM
  #70
DuhCar's Avatar
Anybody disable Eco start on the MY2016’s yet?
Old May 14, 2015 | 01:14 PM
  #71
DuhCar's Avatar
Bump. Looked at doing it today, but not sure that we can do on MY2016. There are quite a few wires going into the module, so it may be possible. Hoping someone has an answer.
Old May 14, 2015 | 02:26 PM
  #72
hardwired's Avatar
At this point, I've just developed a routine. When I start the car after its been off for more than six hours, I drive it in normal mode with the eco mode on. After a couple of minutes, when I feel that I'm ready to drive with enthusiasm, I put the car in dynamic mode and they eco mode goes off as a byproduct.
If I drove the car within a few hours, then I'm probably ready to drive hard as soon as I get in, and dynamic is still on.
I still don't like the eco mode, but I suspect my car has an electrical issue and I don't want to give them any way to blame me for it. I think my current routine is an acceptable alternative.
Old May 14, 2015 | 02:46 PM
  #73
Foosh's Avatar
I just don't get all this discussion and the accompanying angst. You have to press a button to start the car, or to put the car into dynamic mode. Those little exertions don't seem to bother anyone. Why is pressing the eco-mode button so incredibly bothersome for some?
Old May 14, 2015 | 03:04 PM
  #74
TXJagR's Avatar
Seeing as how this is my first car without a real "key", it took me at least a week before I stopped trying to find the key and turn it off in the steering column when I had parked the car.
I also used to always reach in my pocket to get the key to unlock the door and start the car.
I'm ok with pushing a button or two. Still far easier (and more advanced) than any of my previous cars.
Old May 14, 2015 | 03:13 PM
  #75
LynxFX's Avatar
I would rather not be reminded to press the "crap" button every time I get in the car. Gives the car a negative vibe. Having it disabled and never worrying about it again is the preferred method.
On MY14 and MY15, it is such an easy thing to disable.
Old May 14, 2015 | 03:19 PM
  #76
TXJagR's Avatar
One would think that it would be an easy task to default the switch from ON to OFF... reverse the leads? Change a single bit in an ECU file somewhere from 1 to 0, just disconnect the battery.... (oh wait, there is no second battery on the 2016...)
Old May 14, 2015 | 03:22 PM
  #77
DuhCar's Avatar
It's not incredibly bothersome, just bothersome. If you are happy, fine. Others don't like it. I'm just trying to see if the MY2016's can be disabled too.
I'm still in the break in period and am purposely not using the Dynamic mode.
Old May 14, 2015 | 03:23 PM
  #78
LynxFX's Avatar
It really should be a user configurable option especially since they removed that battery.
  #79
Foosh's Avatar
OK, but like I said, I don't get why it bothers you so much, and I still don't.
I've actually been leaving my car in standard auto mode with eco on the last 3 days commute days in a row, just to try to understand why it bothers people so much. However, I still don't see it because I'm in the almost automatic habit of paddling a couple of downshifts as I'm rolling to a stop. When I do that the engine never shuts off.
The few times I've remembered and left it alone, the engine shutdown has occurred, and the restart happens before I can get my foot completely off the brake. In my car, it is completely seamless.
I'm actually starting to like it . . .
Old May 14, 2015 | 03:27 PM
  #80
LynxFX's Avatar
On the V8 it is a much rougher start for the engine to kick over. In my experience it isn't seamless at all. That's the biggest reason why I disabled it.
