How to replace dashboard parts/panels on F Type?
Old Jul 5, 2021 | 03:14 PM
unmhusker's Avatar
Default How to replace dashboard parts/panels on F Type?
Hello everyone!
I own a 2016 F Type R convertible that needs a couple of panels replaced on the dashboard due to damaged leather (specifically #25 and #12 in this parts diagram). Has anyone ever replaced these parts? How hard is it to get these removed? Thank you in advance for your help!
Old Jul 6, 2021 | 10:55 AM
62jeff's Avatar
#12 is the center AC vent assembly. Instructions for removal are elsewhere on this site, and once you remove it you can access the screws that hold the leather in place.
Old Jul 6, 2021 | 11:20 AM
Ray Ray's Avatar
I recently pulled out the center vent, check the links below.
https://www.jaguarforums.com/forum/a...uar-f-type.pdf
https://www.jaguarforums.com/forum/f...emoval-246800/
You need the right extension for the 4 torxs around the speaker, they can't be too long due to the windshield, and can't be too short due to how deep they are down there.
Once you take out all the torxs and disconnected the motor connector, you can go ahead and start removing the unit, I had a hard time with the hinge cover, ended up just keep lifting the unit up and it eventually popped up the hinge cover.
Old Jul 6, 2021 | 11:35 AM
unmhusker's Avatar
Thanks guys, I appreciate the help!
Aidan2001
Sep 25, 2020 10:33 PM
Dell Gailey
Mar 16, 2018 08:20 PM
slypup
Other Areas
May 6, 2014 09:56 AM
kevintbaldwin
Sep 21, 2013 10:08 PM
Jaguar X Type Parts
Aug 30, 2011 02:41 AM
