I Finally Found the BUZZING noise
Old Nov 30, 2017 | 08:50 AM
Don1954's Avatar
Default I Finally Found the BUZZING noise
Finally found the annoying buzz coming from behind me. It is not the privacy shelf. It is in the assembly, overhead, that goes across behind the seats, on the roof. It holds the sunshade assembly when opened. Something in there buzzes when on certain road surfaces. Now, the question is, how to access that and do something to stop that damn buzzing.
Old Nov 30, 2017 | 01:39 PM
ron329's Avatar
I have the same problem and it's driving me craaaazy!!
Old Nov 30, 2017 | 01:45 PM
Don1954's Avatar
Maybe one of the wizards on this forum will come up with a good idea to squelch that buzz!
Old Nov 30, 2017 | 04:11 PM
Burt Gummer's Avatar
Warranty covered item?
Old Nov 30, 2017 | 04:45 PM
OzXFR's Avatar
I'm betting one of the trim clips which hold the cabin bulkhead panel in place has come loose/not fully seated/bent etc.
The F-Type clips look a lot like these (Chrysler ones): https://www.ebay.com/itm/20Pcs-Fit-C...hZ7E05&vxp=mtr
Going through my copy of the Workshop Manual this panel is a bear to get at and remove, as you need to remove a bunch of other trim panels out of the way first, and as usual the Manual instructions are so vague as to be pretty much useless.
Old Nov 30, 2017 | 08:04 PM
Unhingd's Avatar
Try spraying this into the headliner :
Old Dec 1, 2017 | 11:19 AM
Don1954's Avatar
you know, at first thought, great idea! And then we realize that gunk will be all over the sun shade. But keep those ideas coming!
Old Dec 1, 2017 | 02:59 PM
Unhingd's Avatar
yes...please watch for that icon when I offer advice.
Old Dec 12, 2017 | 01:13 AM
pistol's Avatar
Is it a buzz or perhaps a ticking sound? Does it only happen when braking? The latter happened to mine:
Old Dec 12, 2017 | 05:55 AM
Unhingd's Avatar
Originally Posted by pistol
Is it a buzz or perhaps a ticking sound? Does it only happen when braking? The latter happened to mine: https://youtu.be/wUeaJlLshJo
??? I couldn't hear any sound from that video.
Old Dec 12, 2017 | 10:39 AM
pistol's Avatar
You'll have to turn up the volume for the recording. It's definitely there.
Old Dec 12, 2017 | 11:35 AM
Don1954's Avatar
Can't hear it either.
See original posting.
