iCarsoft LR V3.0
Old Feb 7, 2024 | 01:34 PM
Rondog's Avatar
Default iCarsoft LR V3.0
Just received the iCarsoft 3.0 Diagnostic tool. I couldn't find anywhere if this unit has a shutdown before you unplug it or not. Is it OK to just unplug from the car when you are through?
Old Feb 7, 2024 | 03:29 PM
DMeister's Avatar
I'm thinking of picking this unit up as well, so I will listen here with interest. The consensus seems to be that this unit does NOT exhibit the battery draining problem that some others do, but your question is a good one. Is that only if you do some formal disconnect in the software of the unit, or will a physical unplug without doing anything special be okay? Hmmm
Have you used it much at all? What are your initial impressions of it?
Old Feb 7, 2024 | 04:25 PM
scm's Avatar
scm
ISTR OzXFR said he just backs it out as much as he can and then pulls the plug - he says he's never had the drain.
Old Feb 7, 2024 | 04:50 PM
OzXFR's Avatar
Yep.
Mine is a V2.0 not V3.0 but I doubt that makes any difference, what works for the 2.0 should also work for 3.0.
Old Feb 7, 2024 | 04:58 PM
DJS's Avatar
DJS
I’m not sure I’ve seen a report of the drain on an early F-type. I’ve never seen it.
Old Feb 7, 2024 | 10:34 PM
dennis black's Avatar
I would not just unplug it,bring it back to the original screen,incase a module has not finished doing its thing ,it's a great unit you can operate actuators, control air, lights,keys etc, make you upload latest version, it will reset a new battery install replacement
you'll never get a drain with this unit
Old Feb 8, 2024 | 07:31 AM
Rondog's Avatar
Just started using this unit. I don't have any problems or lights, but with 2 F-Type cars, I thought it would be a good investment if future problems pop up.It seems very easy to use and has tons of info on it. I liked it because it was specific to the Jag. I also have anohter iCarsoft unit for other automobile makes. I did go back to the main screen before unplugging it. I also purchased this unit due to other forum members suggustions, along with the fact you can unplug without worrying about your battery being drained.
AaronLin
Feb 10, 2022 11:29 PM
stirlingsilver
Jan 31, 2022 09:56 AM
theswede
Nov 6, 2019 02:02 PM
nalle
Mar 28, 2019 10:03 PM
qwiketz
Jul 30, 2010 01:10 AM
