Interior Tweaks
Old Mar 27, 2017 | 11:07 PM
Burt Gummer's Avatar
I ordered these puddle lights. Looked at these month's ago and I could have sworn they were round and required drilling and were a PITA.
These supposedly pop right in. I like the clean look of this particular projection.
2x Ghost LED Door Step Courtesy Shadow Laser Lights For Jaguar F-TYPE 2013-2015 | eBay
Old Mar 27, 2017 | 11:41 PM
OzXFR's Avatar
Originally Posted by zmoothg
Actually I just installed the illuminated puddle lights today, they are not the same T10 wedge bulbs. Changing the light color would be nearly impossible.
Are you sure?
Coz before I fitted the logo puddle lights I fitted a pair of bog ordinary T10 SMD LED bulbs in there with no problems (although they did flicker a bit!).
Old Mar 27, 2017 | 11:47 PM
OzXFR's Avatar
Yep, they will pop right in.
Pop the OEM ones out (gentle lever with a small flat head screwdriver), remove the connecting plugs, plug the new ones in, click into place, and Bob's your uncle!
The round ones that require drilling are for cars that don't already have puddle lights in the bottoms of the doors (like the XF which has them on the undersides of the exterior mirrors).
Old Mar 27, 2017 | 11:49 PM
Buckingham's Avatar
I was told by an eBay seller that the start/stop switch can easily be pried out with a plastic pet tool without removing the trim. Never tried yet. When the lettering wears off of my switch I may get the ignis orange.
Old Mar 28, 2017 | 02:04 AM
zmoothg's Avatar
Sorry I confused the puddle lights with the illuminated sill plates
Old Mar 28, 2017 | 05:03 PM
Canadairjet's Avatar
Read this thread last night as I went to bed. So of course I had to go to my dealer and do the same thing! Thanks for the idea!!!
Old Mar 28, 2017 | 05:07 PM
WhiteTardis's Avatar
Nice!
Old Mar 28, 2017 | 06:38 PM
  #28
CRS 123's Avatar
I'd love to see pictures on how well these project the logo after you install them. Intriguing.
CRS
Old Mar 28, 2017 | 07:03 PM
OzXFR's Avatar
CRS
They project the logo very well.
In the dark such as at night time they are quite dramatic, but in sunlight or bright light you can't see them at all.
They are also fairly clean and crisp, I was pleasantly surprised how much as I was expecting them to be a bit vague or fuzzy.
As I explained above I can't show you a pic of mine, I tried but the camera flash just completely washes out the logo.
Old Mar 28, 2017 | 07:11 PM
  #30
domino_z's Avatar
the irony is jaguar actually removed the bronze trim pieces (on the R at least) on the mid cycle refresh because of the low perceived quality, especially the shift paddles
Old Mar 28, 2017 | 08:52 PM
  #31
Will do when I get them but they are coming from China so it will be a while!
Funny - I just have to assume for $20 they are junk but others have said otherwise. I love playing with LEDs/lights. I'd like to find bright LED reverse bulbs next.
Old Mar 29, 2017 | 07:17 PM
  #32
Buckingham's Avatar
OK. I ordered an ignis orange start switch. Used to be more than $100, now $25. According to Edmunds, the ignis orange was discontinued because it wore off the paddles leaving the white plastic exposed. So they dropped the entire line of paddles, dynamic control switch and start button. I always liked it and it was pointed out by Jay Leno when he did a Garage segment on a the F Type on his show.
Old Mar 29, 2017 | 07:48 PM
  #33
slojotaa's Avatar
Originally Posted by domino_z
i always wanted the silver shifter base for my R, but after seeing what's involved to get it out, i kinda got over it
i used the osram 5000k footwell leds, matches oe interior lighting perfectly, and swapped out the plastic console trim for oe carbon - made a big diff
Is your car broken? the steering wheel is on the wrong side :-). Seriously the lights and mods look excellent. nice job!
Old Mar 29, 2017 | 08:00 PM
  #34
domino_z's Avatar
it's actually on the same side it left the factory in UK.......and got driven off the boat on the same side of the road
Old Mar 30, 2017 | 04:59 AM
  #35
slojotaa's Avatar
That makes it right I guess, (Right justified). Enjoy it and no matter where the wheel is, the car is the same awesomeness anywhere!
Old Mar 30, 2017 | 08:43 AM
  #36
RickyJay52's Avatar
To each his/her own and there is no right (Joe ) or wrong answer. Personally, I like the look of ignis on the start/stop and paddles and at 18,000 miles haven't noticed any discoloration. And, I would like to think I won't.
Old Mar 31, 2017 | 05:03 AM
  #37
xdave's Avatar
The ignis discoloration issue mentioned doesn't occur for everyone - anecdotally it seems to depend on the amount of acids and other things you have on your skin, what you use to clean your interior trims (you should only use water), and whether the car is exposed to very hot ambient temperatures. Basically the soft-touch clear layer over the painted base breaks down and goes slightly tacky. On areas that have full finger contact like the paddles and start switch that usually leads to gaps appearing where you normally press them, which much like the clear coat on body panels causes the visible colour to change, but it can affect any of the interior switches with that same soft-touch paint finish.
Up till around 2015 that finish was used extensively across many car makes and models to create a more premium plastic finish, until it was addressed. It wasn't just car parts either, I have used TV remote controls and computer mice with the same issue. I don't think the ignis painted parts are still made so replacements likely will experience the same issues if any of the degradation causes are still present.
Old Mar 31, 2017 | 05:40 AM
  #38
Arne's Avatar
On my MY 2015 the ignis starterbutton and paddles looks just like brand new still. No sign of discoloration what so ever.
Hope it stays that way as I actually like that little color "touch" in the interiour.
Old Mar 31, 2017 | 07:27 AM
  #39
Buckingham's Avatar
I think I'll clear coat mine before installation or just buy 5 while they are available.
Old Mar 31, 2017 | 11:29 AM
  #40
jfranks's Avatar
Because of this thread, I bought both the logo ghost lights for the doors, and the copper start button.
The start button installed in five minutes. I used a trim tool to pop the shifter trim ring up, disconnected the harnesses, and swapped out the buttons. I paid $30 shipped for the button on eBay.
The ghost lights were $20 from China, so I should be seeing those in the next 8 weeks haha.
