Koshi interior parts question
Old Apr 5, 2021 | 08:19 AM
  #41
Jaguar1611's Avatar
Originally Posted by 19FRG
Man this is really good stuff got rest of first order today.
Did the pieces go right on top and cover the OEM? The ones I just put on my steering wheel were a perfect fit as a cover without even 3M tape (other than the part that goes around the R badge.)
I'm considering getting these pieces in your picture. I got the handle...and like you didn't think it would fit at first.
Old Apr 5, 2021 | 08:27 AM
  #42
Jaguar1611's Avatar
Old Apr 5, 2021 | 11:44 AM
  #43
bcbruno's Avatar
Cool in orange too
About other parts:
Since i want to keep exhaust exterior as stock, did asked them if possible make exhaust sleeves as they do for Alfa's, they willing to see a drawing to considerate so i sent them this:
Opinions?
Old Apr 5, 2021 | 12:15 PM
  #44
gg2684's Avatar
Originally Posted by bcbruno
Cool in orange too
About other parts:
Opinions?
I had some made that are about the same size, but I did cut the factory tip and made sleeves to accept the new tips - they are also ceramic black tips with gloss carbon sleeves that match the wheels and other exterior carbon.
Old Apr 5, 2021 | 12:35 PM
  #45
bcbruno's Avatar
Awesome, That's exactly the look i am looking for, I would prefer don't cut stock due warranty, etc but perhaps that is the easiest way to do it and all black.
Could you provide info where you order those?
Old Apr 5, 2021 | 03:38 PM
  #46
gg2684's Avatar
I found a seller on eBay - they were making them for BMW’s and I asked if they could make them for me without the “M” logo and in custom lengths. They are 94mm in diameter and I would have to go back and get the exact measurements but the inside tip is longer than the outside. I think I recall the lengths being 90mm outer tips and 120mm or 140mm inner tip with the inlet being 2.5”. The inside pipe is mallet so you will need an adapter to go from 2 1/4” to 2 1/2. Basically pulled the tear muffler assembly off, cut the tips of, evened up the pipes and then welded the sleeves in the inside. The last thing to do is make final
adjustments which were made using original measurements so the new tips come
out exactly as far as the originals.
Old Apr 5, 2021 | 05:16 PM
  #47
mrjohnt's Avatar
Originally Posted by Jaguar1611
The steering wheel pieces just clipped onto the “sticky” oem wheel? Also what color is your car? Do you think the orange CF would clash with IRR? (Paddles are orange at least) Regular black CF seems boring
Old Apr 5, 2021 | 05:46 PM
  #48
bcbruno's Avatar
Thanks, great info and dimensions are correct according my measurements, i will give a try on ebay
Old Apr 6, 2021 | 09:47 AM
  #49
Jaguar1611's Avatar
Yes they fit perfectly as a cover without tape or removing any part of the wheel. It only took me about 60 seconds to put it on just right. My car is Dark Sapphire. Well, you already have the orange paddles...so I'd think more orange would look cool!
I must say the orange color looks phenomenal in how it changes based on natural light levels. The pictures don't do it justice.
Be advised, I placed my order through Madness Auto back in December and the parts just arrived last week
Old Apr 6, 2021 | 10:01 AM
  #50
Jaguar1611's Avatar
What a beauty!!!
Old Apr 6, 2021 | 10:52 AM
  #51
gg2684's Avatar
Thanks, I painted the remaining pipes and muffler belly so its just black from every angle.
Old Apr 6, 2021 | 03:10 PM
  #52
mrjohnt's Avatar
That’s where I am going to purchase from. At least you got the parts. Patience is a virtue?
Old Apr 6, 2021 | 06:42 PM
  #53
bjg625's Avatar
I also used Madness and very satisfied with result. Waiting on door switch covers due end of April. Also got the steering wheel rim covers which appear to be in stock. I just returned a duplicate shipment of the center console parts so they should have them in stock in a few days if you don't want to wait. I shipped today.
Old Apr 7, 2021 | 03:57 AM
  #54
JacksonvilleJag's Avatar
I got a couple pieces directly from Koshi. They first insisted on a wire transfer, but when I told them that my bank charges $60 for an overseas wire and that would change my mind on the order, they accepted paypal. Took about 11 days to Florida.
Old Apr 7, 2021 | 06:49 AM
  #55
Jaguar1611's Avatar
Do the center console parts cover the OEM? Or do you have to remove them. Thanks for that info!
Old Apr 7, 2021 | 08:32 AM
  #56
Yes, they cover OEM. Most folks use the thin 3M tape to adhere.
Old Apr 7, 2021 | 04:21 PM
  #57
bjg625's Avatar
Used tape on 2 of the pieces and one snapped on firm. Took longer to peel back of tape than anything else.
Old Apr 18, 2021 | 11:31 AM
  #58
Stuart Satter's Avatar
Did you think about the top and bottom steering wheel covers as well? I purchased the carbon bits in black for my car. Might pulll the trigger on the cf upper and lower. However, I don't see the seems. I wonder where they are.
Old Apr 18, 2021 | 11:32 AM
  #59
How do the seems fit on the steering wheel cover for the CF upper and lower. Can you show me a pic?
Old Apr 19, 2021 | 04:31 PM
  #60
Timbo's Avatar
The dash board trim pieces, ie gear surround, heater surround and upper are replacement parts, well they were on mine.
