Larger v8 supercharger
Old Nov 9, 2019 | 12:34 PM
Terrance39's Avatar
Default Larger v8 supercharger
Anyone know if there is a larger supercharger available for the v8?
Old Nov 9, 2019 | 02:11 PM
George05's Avatar
Dont think so
Old Nov 9, 2019 | 04:05 PM
Unhingd's Avatar
Yes there is. The FT-R uses a TVS R1900. Eaton makes a TVS R2300.
Old Nov 9, 2019 | 04:54 PM
Ltrain925's Avatar
they make it for the 5.0 v8 f type r? I haven’t found any info on that.
Old Nov 9, 2019 | 05:00 PM
OzXFR's Avatar
No, they don't make the R2300 for the AJ133 engine and to my knowledge no-one has ever tried to fit an R2300 to the AJ133 as it would be a massive and very expensive exercise.
Old Nov 9, 2019 | 06:27 PM
BruceTheQuail's Avatar
Is it the case that if you put a substantially larger supercharger on to a car also have to upgrade the fuel system to deliver more fuel?
Old Nov 9, 2019 | 06:54 PM
OzXFR's Avatar
Maybe, maybe not.
There is some discussion on this forum about the duty cycle and the head room of the stock fuel injectors on the AJ133SC, ie can they / will they flow enough already for a big power increase to say 750 hp, and I don't remember seeing a definitive answer to this question. But I do remember reading somewhere that the AJ133SC was designed from the get go for a max output of 700 hp, with the Eaton TVS R1900.
Old Nov 10, 2019 | 04:51 AM
Paul_59's Avatar
Banned
As OzXFR states no one makes one to bolt on to Jaguar V8.
Indeed I believe Eaton (manufacturer) doesn't even sell their TVS supercharger to end users.
They appear to be available via a small number of distributors
Magnuson
Roush
Edelbrock
Harrop
TVS distributors
The complete unit is integral with an air to water intercooler that must obviously mate to the Jaguar AJ133 V8 inlet manifold (and fit under the bonnet - hood)
They are available as bolt on upgrade kits for Ford GT500 for example.
I think a custom solution would cost serious money as bolt on for Ford are in excess of $5000 if memory is correct.
That said if anyone was determined enough and had deep pockets (lots of spare cash) then the one to go for would be the larger TVS R 2650.
Although some may say that it's a larger displacement than needed (designed for engines up to 6.2L) crucially it's a more efficient design than either the TVS R 1900 fitted as standard or the next size up TVS R 2300.
It provides more airflow (obviously) but importantly takes less power to drive it.
All other things being optimised more airflow equals more power produced and less power to drive the blower means more of the increased power gets to the wheels.
Obviously big money needed to upgrade ZF8HP gearbox as the standard V8 maximum torque output is already extremely close to 700Nm limit of our transmission, though upgrade should be simple as there's a 900Nm variant available from ZF.
Probably fairly wise to spend money upgrading engine, brakes etc.
Great to imagine the beast it could be turned into with sufficient time, money and dedication.
Probably reasonable estimate would be 800bhp without difficulty, but eye watering cost!
Certainly on my fantasy upgrade list
TVS R2650
TVS R2650 detailed specifications
Old Nov 10, 2019 | 06:10 AM
Unhingd's Avatar
The ZF8 has been used on vehicles pumping out well in excess of the advertised torque limit. I wouldn’t hesitate to use it on a 700-800hp application. Stuffing a larger SC on top of an engine merely requires access to a big hunk of aluminum and a milling machine to construct the mating IC. The same Heat exchangers could be used as the oversized SC should be operating at cooler temps. This is a process I am contemplating for my V6. However, with the manual transmission, I will definitely need to upgrade it (ZF S6-53).
Old Nov 10, 2019 | 06:30 AM
RacerX's Avatar
Banned
We have the ZF8HP70 which is rated, probably not by accident, to the exact same 516 ft-lbs (700 nm) the SVR is tuned to put out. Makes you wonder what the V8 is really cabable of. But higher torque cars use higher rated ZF8s.
Old Nov 19, 2019 | 12:58 AM
Stuart@VelocityAP's Avatar
2300 isn't a big enough step to make that much difference with heat. We're evaluating some options pretty seriously right now. Chris is doing Science!
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Old Nov 19, 2019 | 03:31 PM
Paul_59's Avatar
Banned
If we are considering Rootes style blowers (Eaton TVS are essentially modified Rootes style, albeit more efficient than previous M series)
Having read extensively about TVS R 2300 and 2650
Like I said any serious supercharger upgrade would use 2650, it displaces approximately 40% more volume per rotation than R1900.
It's different rotor geometry contributes to greater efficiency, lower outlet temperature (pre intercooler). More airflow volume obviously more power potential, lower outlet temperatures means increased mass for any volume as higher density, bigger intercooler also helps. Lower parasitic drag and lower power to drive than 2300 is an extra performance bonus.
Running standard supercharger faster via different pulleys will as many have found give some useful power increases however these gains are a little like power upgrade from turbo cars, they only get you so far with the standard OEM sized blower (whether supercharger or turbo charger) before the engine is running in a part of the compressor map that is less efficient.
This situation gives some increased airflow (good for power increase) at the expense of higher air temperature , lower density air (leads to power decrease) plus Spinning supercharger faster uses more power to drive the blower and the power to drive any supercharger will increase in proportion to speed of rotation (actually proportional to square of rotation speed if memory serves) which reduces power available from engine / ,blower combination.
Regarding earlier question about fuel injectors flow capacity, does anyone know the specification of OEM standard.
Port injection can gave some increased fuel flow from standard injectors by running higher fuel pressures , only if significantly greater fuel flow does injectors replacement become desirable.
With direct injection increased injection pressure option may be less straightforward.
I suppose an expensive and complicated solution might be to combine standard direct injection with additional port injection, additional benefit of reducing inlet valve / port carbon build up.
Old Nov 19, 2019 | 03:47 PM
The 2650 is the one!
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old Nov 19, 2019 | 03:56 PM
Paul_59's Avatar
Banned
You've got my attention.
Better start saving
Old Nov 19, 2019 | 04:25 PM
Ltrain925's Avatar
Take my money! And throw some e85 at it! 😁
Old Nov 20, 2019 | 06:31 PM
Stohlen's Avatar
This sounds dangerous... Sign me up as test dummy.
Old Jun 14, 2020 | 02:07 PM
Tuggerbutz's Avatar
Has there been any progress on this adventure? I’ll definitely be following this.
Old Jun 14, 2020 | 07:53 PM
supersportmtl's Avatar
Id love to bolt on a 2650 with hood cutout for fitment lol MadMax this bitch
Old Jun 16, 2020 | 06:33 AM
Stuart Satter's Avatar
Im curious as well as to the future options.
Old Dec 30, 2020 | 07:55 PM
Thomas keal's Avatar
brb taking screen shots to local shop to get estimates 😂
