Lead Battery replacement
Old Oct 8, 2022 | 11:39 AM
steiner's Avatar
Default Lead Battery replacement
Hi Guys,
i own a 2017 Jaguar F type V6s with about 40k miles.
i am wondering if I can use a Boosch Lead battery in my F type?
the picture is attached.
Old Oct 8, 2022 | 11:52 AM
sov211's Avatar
You can use any AGM battery because that is what the charging system is set for.
Old Oct 8, 2022 | 11:54 AM
steiner's Avatar
The lead battery in the attached picture isn’t AGM, so was wondering if it can replace the AGM since it has same rating.
Old Oct 8, 2022 | 04:59 PM
sov211's Avatar
Possibly…but as I wrote, the charging/monitoring system in the F-Type is set up for AGM batteries, not traditional wet batteries. So yes, the battery pictured will function in the car but the charging system may or may not charge it appropriately. Bext to stick with OEM specifications.
Old Oct 10, 2022 | 03:50 PM
chasers03's Avatar
My research says the Bosch S5 is AGM? I replaced my 2016 battery with an Antigravity H8/Group-49 Car Battery and have never looked back....Love it.....
Old Oct 10, 2022 | 07:39 PM
steiner's Avatar
thanks all I will give it a try and share feedbacks
Old Oct 10, 2022 | 07:51 PM
OzXFR's Avatar
My research says otherwise, that it is a flooded cell (wet) lead acid battery, see here: https://www.supplyvan.com/bosch-s5-0...00ah-830a.html
Note where the specs page says "Technology: wet".
Old Oct 11, 2022 | 09:22 AM
kb58's Avatar
For critical specs, I always use the manufacturer's site. Resellers frequently have errors in their ads, due to copying page content from one to another and frogetting to change everything.
Bill W
May 23, 2024 05:19 PM
NavyBlue
Apr 12, 2022 11:15 AM
1100me
Aug 9, 2014 01:49 PM
abonano
May 12, 2012 02:47 PM
JagXType620
Sep 2, 2009 02:52 PM
