Lean Exhaust
Old Aug 17, 2021 | 10:14 AM
richled's Avatar
Cool Lean Exhaust
Hi all,
Hoping I can bend your ears for some advice. The check engine light came on and I took it to a local mechanic to diagnose the issue. Keep in mind I live in Cape Breton, Nova Scotia and the nearest dealership is a 4 hour drive away. The local mechanic told me it was diagnosed as 'Lean exhaust condition on bank 2', and cleared the code thinking that the insanely loud stock exhaust was aftermarket. The car is still under warranty. My question is, should I have it towed to the nearest dealership 4 hours away? Is the fact that he cleared the code going to have any repercussions as it pertains to warranty, etc?
Thanks for your time and input!
Old Aug 17, 2021 | 02:16 PM
Therock88's Avatar
Originally Posted by richled
Hi all,
Could be an O2 sensor, Injector, MAF sensor. Etc.. If it is under warranty, I would absolutely have it towed (Flat Bed) to the dealer. Clearing that code will not throw them off. I assume he used a generic OBDII Scan tool (So make sure your battery does not start draining now). The SDD or Pathfinder software the dealer will use, will have a history of all of the events...So you should be fine.
Good luck...
DC
Old Aug 17, 2021 | 02:47 PM
DJS's Avatar
DJS
This might be helpful if you can get the actual code:
https://www.dropbox.com/s/1ek33ux7tf...guide.pdf?dl=0
Old Aug 17, 2021 | 03:39 PM
Luc Lapierre's Avatar
Is that true?
A service advisor told me that they couldn't perform warranty work without a code actually present.
I had cleared it with a cheap scanner (wasn't thinking ).
I was simply asked to come back if/when the CEL returned.
Also: +1 on the battery.
As many have recommended before: disconnect & reconnect the battery to be sure.
Old Aug 17, 2021 | 03:57 PM
Therock88's Avatar
Originally Posted by Luc Lapierre
Is that true?
Yes...Not sure what their protocol is for doing or not doing the work. But I actually have the JLR Dx software, and I can clear codes, and it still shows in the DTC history...all of it. You can do a complete wipe with the JLR tools, but not with generic scanners.
To make it more "difficult" for customers, some will say, even though the code is stored, they have to actually see/hear the issue...So there's that. Cannot speak to the JLR repair protocol only that I have seen the historical codes in the listing even after they have been cleared. It is very detailed too...It tells you the time of day, temp, what happened, how many times etc...
DC
Example below...You can click the icons to the right and it drills down to all sorts of data, symptoms, suggested fixes, etc...
xialiulaoren
Nov 22, 2022 02:24 AM
malbec
Jan 11, 2021 12:42 PM
RichardCranium
Oct 25, 2019 09:59 AM
Jfry61
Aug 14, 2017 10:19 PM
DJ99
May 24, 2012 08:10 PM
