Magnetic oil drain plug
Old Jan 22, 2022 | 06:48 AM
KyleB's Avatar
Default Magnetic oil drain plug
Anyone have a source for a quality magnetic drain plug in the US? Thanks
Old Jan 22, 2022 | 09:47 AM
2018XF25T's Avatar
Search on Gold Plug. Made in USA. They make drain plugs for Jaguars from 2009 or older. "Maybe" the older Jaguar models' drain plugs might fit into your Jag
Old Jan 22, 2022 | 09:48 AM
Therock88's Avatar
Have not seen, or come across any magnetic plugs for these to date. Many on here use the MityVac or similar system, and do not drain their oil, so many may not be looking?
I use an EZ (ball style) plug with a drain hose for mine. You could consider finding another compatible MAGNETIC drain plug as the size is: M14-1.50; Head Size 16MM. These also have a seal washer on them.
Good luck.
DC
Old Jan 22, 2022 | 10:34 PM
tzoid9's Avatar
Or, you can just cut the engine oil filter open and inspect the pleats. You’ll see more contaminants in it, especially non ferrous particles, if you’re that concerned.
Old Jan 23, 2022 | 07:06 AM
KyleB's Avatar
I do that too! And an oil analysis.
CCM911
XJ40 ( XJ81 )
Feb 25, 2021 05:32 AM
gtmaster303
Sep 14, 2014 08:02 AM
aviation14
Sep 9, 2014 03:57 AM
snooktarpon
May 17, 2008 07:43 AM
