XJ40 ( XJ81 ) 1986 - 1994
Drain in front on oil sump
Old Feb 24, 2021 | 02:02 PM
CCM911's Avatar
Default Drain in front on oil sump
Hello:
I am sure this is a really dumb question, but what is the purpose of the large brass plug on the front of the oil sump? Mine appears to be leaking. Could I remove it without anything falling out, or requiring adjustment?
1989 XJ6 Base.
Thanks so much.
Old Feb 24, 2021 | 07:30 PM
jerry_hoback's Avatar
My oil drain plug is at the rear on,,,,,, all of them. Please post a pic of this plug. I am curious what you have there.
Old Feb 25, 2021 | 05:32 AM
CCM911's Avatar
I found what it is. Of course the drain plug is in the rear of the sump. But up front, you will find a large brass plug, which is for access to the oil pressure relief valve. And yes, it can be removed in order to replace the leaky copper crush washer.
dpresent
Nov 5, 2017 09:57 AM
gtmaster303
Sep 14, 2014 08:02 AM
snooktarpon
May 17, 2008 07:43 AM
ikeholt40
Nov 2, 2007 12:41 PM
