Make the horn sound when locking?
Old Nov 14, 2022 | 09:43 AM
LarryDawg's Avatar
Default Make the horn sound when locking?
My 2017 SVR does not make any sound when locked with the remote key. Is this an option somewhere I have not found?
Old Nov 14, 2022 | 10:37 AM
355rockit's Avatar
My 2015 R doesn't make a beep sound on first press of lock with the remote. Press lock a second time and it will beep the horn.
Old Nov 14, 2022 | 11:21 AM
scm's Avatar
scm
I think the beeps are market-dependent, too.
Old Nov 14, 2022 | 12:43 PM
NewLester de Rocin's Avatar
For 2015 through 2018 models of F-XE and XF (...so perhaps the F-Type also), getting an audible "beep" confirmation when you used the remote was set up from the TFT (the menu you see between the two dials on your instrument cluster---NOT the infotainment screen menus).
Somewhere in "Vehicle Features", then "Security", you could drill down and find "audible confirm" or something similar to these wordages.
But I believe 355Rocket's experience applies to our XE's too. Jaguar at the time was biased AGAINST making a whole lot of horn and beeper sounds when you're just entering or leaving your car---they kind of downplayed that on fancy cars around those years.
Your remote, like 355Rocket's may still only get a horn/beep when you double-press (double-lock) your button. (First press locks your car SILENTLY---the beep on the second press is your car's way of saying "stop that---I'm already locked!"). LOL,
Old Nov 14, 2022 | 05:06 PM
OzXFR's Avatar
My MY2015 F-Type has that setting, I turned it off years ago.
Old Nov 14, 2022 | 05:23 PM
scm's Avatar
scm
.... may still only get a horn/beep when you double-press (double-lock) your button. (First press locks your car SILENTLY---the beep on the second press is your car's way of saying "stop that---I'm already locked!"). LOL,
In the UK that beep is telling you the car has been deadlocked so doors cannot be opened from inside the vehicle, and the full alarm system is activated (single locking only activates the perimetric alarm and prevents doors being opened from outside), so movement inside the car, battery disconnect, vehicle raised or tilted, or glass broken will trigger the alarm. I believe that in some markets a single press will activate the full alarm system.
Cibermac
XE ( X760 )
Aug 24, 2022 11:13 AM
Ubad2
May 30, 2019 07:18 AM
a6kmita
Apr 29, 2017 01:14 PM
harryf
Jul 9, 2015 04:43 PM
