Mechanical Vacuum Pump Delete Kit - Any how to....
Old May 23, 2025 | 09:28 PM
Enisada's Avatar
Default Mechanical Vacuum Pump Delete Kit - Any how to....
Hello,
Curious has anyone had experience installing Mechanical Vacuum Pump Delete Kit from VAP. I am tackling it tonight. I have removed the mechanical pump and sealed it off with the blank plate. But I am just going off of the pictures from the website and need just a bit more on the best place to grab power and routing of the vacuum lines.
Mechanical Vacuum Pump Delete Kit Jaguar Land Rover 3.0 & 5.0 Supercharged Engines - Velocity Automotive Performance
Old May 25, 2025 | 03:50 PM
Enisada's Avatar
Alright all installed, was able to provide power from the main power fuse box on the driver side. Noticed that the mechanical pump is pretty loud when it is creating vacuum, cycling when brake pedal is pressed, mostly noticeable at low speed, tapping the brakes when parking. Any thoughts on this, feel it should be quieter.
Olav
Aug 8, 2023 12:56 PM
racerxf12004
May 5, 2023 06:11 PM
2011_XF_5.0
Jul 17, 2022 09:44 PM
justanurse
Jan 31, 2020 11:17 AM
Tork Monster
Feb 5, 2019 03:37 PM
