Red triangle
Old May 25, 2025 | 07:57 PM
bjg625's Avatar
Default Red triangle
I noticed red warning triangle is always on. Is this right?
Old May 25, 2025 | 08:44 PM
Thunder Dump's Avatar
It should stay on for approximately 10 minutes after the car is turned off/locked. If it stays on constantly, that's an indication that the car is not going to 'sleep' properly because some modules are still active--most likely the result of an improper disconnect of a device on the OBD II port.
Simple fix--disconnect the negative lead from the battery for 30 seconds and reconnect. You'll have to reset the auto up/down window function but otherwise all other settings should be preserved.
mawheele
Oct 7, 2020 05:38 PM
Nickers
Oct 5, 2020 02:49 PM
DuhCar
Dec 29, 2014 11:33 AM
BriteRed01XKR
Sep 8, 2011 09:47 AM
