Must Replace rotor?
Old Sep 12, 2018 | 12:14 PM
Don1954's Avatar
Default Must Replace rotor?
I inquired at my dealer what the labor cost is to replace the brake pads.
They advised $290.00 for the front and $290.00 for the rear. But! You must change the rotors too as they cannot be turned.
Is this the fact jack? Is this true?
Old Sep 12, 2018 | 12:18 PM
SinF's Avatar
It is unlikely you need new rotors on 2016 unless there is an issue. More so, I heavily track my car and I am still on original pads and rotors.
However, YMMV as I rarely use brakes outside of track situations.
Old Sep 12, 2018 | 12:35 PM
Don1954's Avatar
I only wanted to change the pads to get less dirty dusty messy pads. No real issues other than dirt.
Old Sep 12, 2018 | 06:48 PM
OzXFR's Avatar
Most dealerships will claim that the rotors also need replacing every time the pads are renewed.
They usually claim "for maximum braking efficiency and peace of mind you need to renew both at the same time".
IMHO and after lots and lots of research and experience across two XFs and the F-Type this is BS and simply a standard con from the dealership to generate more revenue from unnecessary rotor replacement. I had the OEM rotors on both the XFS and XFR turned/machined when fitting new pads the first time (not long after I bought each car) and not a single problem, the brakes worked perfectly afterwards.
As we know the OEM brake pads on the F-Type wear fairly quickly and so do the rotors, as they are both fairly "soft", and a good portion of the massive amounts of brake dust you get with OEM pads and rotors is actually from the rotors not just the pads.
But in 99% of cases you should easily get two fully worn out sets of pads out of one set of rotors.
The idea is to measure the rotor thickness (all four) when you are ready for a pad change and determine if the rotors are within minimum thickness spec or not.
If they are thicker than minimum spec you are good to go for another set of pads, if under minimum specified thickness then at least for insurance purposes you should renew the rotors as well.
According to the Workshop Manual the specified minimum thickness for all Jag rotors is 2 mm less than new.
For example with the F-Type "super performance" brakes (380 mm front and 376 mm rear) front new rotor thickness is 36 mm / 1.42" and minimum thickness is 34 mm / 1.34" while rear new rotor thickness is 26 mm / 1.02" and minimum thickness is 24 mm / .94".
So JLR are saying that 2 mm of wear or a whopping 1 mm each side takes them to minimum specified thickness, which IMHO is excessively pessimistic and the rotors are almost certainly still perfectly OK at another 2 mm thinner, especially the fronts.
But of course you take a risk running rotors slightly under minimum specified thickness that the insurance company might deny a claim.
Bottom line - don't take the dealer's word for it, measure the thickness of all four rotors yourself (very easy to do with a vernier caliper) and then decide if you want/need to replace them. If you decide to keep them it is always a good idea to get them skimmed when fitting new pads.
Old Sep 12, 2018 | 06:55 PM
SinF's Avatar
Bad idea. Dust is the lesser evil. Alternatives are noisy pads or pads that won't work as well as OEM.
Old Sep 12, 2018 | 07:05 PM
Chawumba's Avatar
That hasn't been my experience, at least on the street. Porterfield pads seem comparable to OEM but with 70% less dust, initial bite is a little less than OEM (which is a good thing on F type - I hated the grabbiness at slow speeds) and I have not experienced noise with them on either my F type or my M3. But hey, as they say, YMMV.
Old Sep 12, 2018 | 08:40 PM
Unhingd's Avatar
Don,
I concur with OZ that new rotors are unnecessary unless you are pushing 50 or 60k miles. No one will turn the rotors, as the brand new spec is probably identical to the minimum spec in the maintenance book. Even if your rotors have a few minor ridges in them, the new pads will conform perfectly within a couple hundred miles.
Old Sep 12, 2018 | 08:54 PM
ndabunka's Avatar
We are missing critical details here that would be needed prior to our ability to formulate an appropriate response. How many miles are on the car now and have you engaged in any "excessive" wear and tear during that period? If you are a typical "spirited" driver who may occasionally travel some twisty mountain roads then you may need to replace the rotors at 50K or 60K. If you "drive like my 99 year old grandma did never exceeding 45MPH in a one-stop light town on the flat plains of Iowa (Seriously, she lived in Cresco IA & still drove @ 99 years young ) then you may be able to put 100K miles on it before needing rotors. If, on the other hand, you are tracking it on a weekly basis then perhaps the rotors "might" need to be replaced in as few as 25K miles so... What is the current mileage and which type of driver are you?
Old Sep 13, 2018 | 08:26 AM
Carbuff2's Avatar
The OP (Don) stated that the pads are not worn out, he just wants a less dusty pad/wheel.
Of course, the most accurate response is to 'measure rotor thickness first, then decide for yourself'. If a dealer won't do it that way, go to an independent shop. (Which I would do anyway, its not a warranty situation at all...)
That said, I think that Jaguar's conservative wear specs are because the rotor DOES contribute to heat dissipation. If it's too thin you are on 'thin ice' to coin a phrase.
Even if you really want to get your money's worth, don't let yours wear this far, OK?
Or
Old Sep 13, 2018 | 10:24 AM
lizzardo's Avatar
At least part of this is the dealer is covering themselves in case of a come-back. If they replace the pads only and the brakes have issues, such as squealing, they'll have to do the job again on their own dime.
I never turn rotors, but also do my own brake work. I save on labor, and replace rotors with pads because I don't want to go back in. I've got more interesting things to do with my time. I may feel differently with my expensive two-piece rotors when the time comes, but my micrometer will have the final say.
Old Sep 13, 2018 | 12:45 PM
Don1954's Avatar
Default Thank you all
Thanks you all for your replies and techno advice.
Car has 11k miles, no issues other than dust. Looked up Porterfield prices for pads, decided to wear mine out first.
Cleaning wheels is therapeutic right?
Old Sep 13, 2018 | 02:44 PM
Unhingd's Avatar
We should probably check with the Wortec to find out what they consider to be the minimum specs.
Old Sep 13, 2018 | 08:24 PM
Mbourne's Avatar
it can be
Old Sep 14, 2018 | 07:28 AM
fujicoupe's Avatar
Banned
I enjoy keeping up the appearance of my car, but that doesn't include having to clean the wheels after a 10 mile jaunt! The amount of brake dust the car creates is insane.
Old Sep 14, 2018 | 07:30 AM
Ron Gillespie's Avatar
The majority of high performance cars all produce insane amounts of brake dust. Very common topic across car forums of all makes and models. My last two Porsches were both horrible - certainly some pads where better than others, but still all were bad.
Old Sep 14, 2018 | 07:40 AM
Carbuff2's Avatar
I need to learn NOT to lick my finger after I touch the wheel to see if its dusty. (It always is )
Old Sep 14, 2018 | 11:11 PM
Greggbhill's Avatar
you might look into coating wheels with ceramic (cquartz, opti-gloss,etc) to reduce brake dust sticking, and use wheel cleaner like Sonax or Griots heavy duty.
Old May 27, 2024 | 01:19 PM
Luc Lapierre's Avatar
Did anyone ever hear back on this?
Old May 27, 2024 | 01:39 PM
Valerie Stabenow's Avatar
Default The ceramic coating does work with brake dust
I used Avalon King ceramic on the car and after wasting bottles of wheel cleaner, I finally wised up, cleaned and IP alcohol wiped the wheels and put some AK on them, too. Now all I have to do is car soap them up, take a detail brush and work it around all the little corners, rinse and all good.
Old May 28, 2024 | 01:21 PM
For anyone wondering, I enquired:
