MY2018: Difficultly Engaging Reverse and No Natural Roll
Old Oct 29, 2018 | 08:49 AM
raweikert's Avatar
Default MY2018: Difficultly Engaging Reverse and No Natural Roll
Only 600 miles on new MY2018 (automatic) and a couple of times now when I put it in reverse it doesn’t engage and won’t rolll back naturally. I tap the gas and it lurches back with a noise as if I’ve run over something or the reverse gear suddenly engages. Strange. This doesn’t mean my transmission is about to go out, does it? How can that be on a brand new car? Thoughts?
Old Oct 29, 2018 | 09:51 AM
scm's Avatar
scm
Has the parking brake engaged? If it has that might explain the reluctance to roll back, and the lurch when you tap the throttle.
Old Oct 29, 2018 | 09:54 AM
raweikert's Avatar
That’s an interesting thought and would make sense the way it sounds and acts. But normally when I shift to reverse the parking brake automatically disengages with me not having to do anything. Is a “sticky” parking brake a known quirk or problem for these cars?
Old Oct 29, 2018 | 10:02 AM
scm's Avatar
scm
As I understand it, the EPB engages automatically when you select P. If you go straight from D to R it shouldn't engage, so it seems the mystery deepens. I haven't noticed any jerkiness when my EPB disengages automatically on throttle push, it seems to be smoother than the release on my previous XKR.
Old Oct 29, 2018 | 10:05 AM
raweikert's Avatar
Correct. And to be clear, this has only happened twice and when I have started up the car for the first time in the morning and when I am shifting from Park to Reverse.
Old Oct 29, 2018 | 11:01 AM
scm's Avatar
scm
Ah, then I'd say it's definitely the EPB release. I've sometimes noticed mine is little "sticky" first thing, so maybe it's a characteristic of the EPB.
Old Oct 29, 2018 | 11:06 AM
raweikert's Avatar
Very helpful. Thank you. The other thing that just occurred to me is that I believe both times this happened I had just washed the car and wheels (very thoroughly including the inside of the drums; wheels not removed) the day before. That was certainly the case this morning. I wonder if that has something to do with it.
Old Oct 29, 2018 | 11:08 AM
scm's Avatar
scm
I always drive my car after a wash, just to shake out any drops.
Old Oct 29, 2018 | 11:15 AM
Arne's Avatar
So do I, including some hard braking and a quick use of the electronic handbrake (while in motion), to heat up the brakediscs and evaporate any water/moist.
That will prevent rust building up on the discs, and ensure a problem free start next time
Old Oct 29, 2018 | 11:21 AM
raweikert's Avatar
Great and sound advice. Thank you. That will now be part of my wash regimen!
Old Oct 29, 2018 | 11:36 AM
DJS's Avatar
DJS
Yes, likely related to washing (or rain) and rusty rotors. I've noticed something similar.
Old Oct 29, 2018 | 11:59 AM
raweikert's Avatar
Again many thanks. Any thoughts about how best to address any rusty rotor issues, although again my car only has 600 miles on it. Can’t imagine it is too bad at this juncture.
sov211's Avatar
You have just identified the problem: a light coating of rust on the brake discs which "freezes" the brake pads to the disc. The car will not move until sufficient force (through the accelerator) is applied. This is perfectly normal, entirely non-harmful and can occur on any car (and does) in such conditions.
and for the record, the parking brake does NOT apply automatically when the P button is pushed. Ithe brake button must be raised manually to apply the parking brake, but it does release automatically when any gear other than N is selected.
Old Oct 29, 2018 | 12:15 PM
raweikert's Avatar
It’s interesting, but when I have the Auto Start/Stop feature activated the EPB often does automatically engage when I put it in P.
Old Oct 29, 2018 | 02:37 PM
scm's Avatar
scm
To update the record, it applies automatically when P is selected on my MY18 R AWD.
Old Oct 29, 2018 | 03:06 PM
DJS's Avatar
DJS
Yup, they changed it at some point. Doesn't apply automatically on my 2014 F-type (does on my 2018 XE.)
Old Oct 29, 2018 | 05:55 PM
sov211's Avatar
There is no issue to address; the rust formed when a car gets wet but not used immediately after is perfectly normal and happens with any car. Drive it for 5 minutes, apply the brakes once or twice and the rust is gone.
Old Nov 5, 2018 | 07:39 PM
16fnrbrg's Avatar
FWIW, when I park on an incline, I engage the park brake BEFORE selecting Park, otherwise there's a bit of a clunk when next I drive away.
Old Nov 6, 2018 | 06:33 AM
scm's Avatar
scm
When I had my XKR I read somewhere that selecting P before engaging the EPB could put some strain on the gearbox, so I've got into the habit of always applying the EPB first now.
Greggbhill
Aug 26, 2018 11:09 PM
cgnFT
Mar 5, 2018 11:37 AM
jallitt
Nov 18, 2017 10:28 PM
alextoevs
Dec 15, 2015 08:09 PM
Jan 15, 2006 02:29 PM
