Need help/guidance on detaching wiring harness from powered liftgate
Old Dec 26, 2023 | 10:25 PM
OneTinyFatGuy's Avatar
Question Need help/guidance on detaching wiring harness from powered liftgate
Hello all! I am currently in the process of replacing the trim inside the rear boot/trunk that guides rain water to their respective drain holes. The adhesive and trim themselves are not in very good condition. I am looking for any help or guidance on how to detach the wiring harness (I think that is what it is?) between the body and liftgate. Below is a picture for reference. Once removed I should be able to remove and replace the trim pieces.
Old Dec 27, 2023 | 07:30 AM
Rob Schwartz's Avatar
I don't know if your car is under warranty still, but if it is, I had that trim replaced and they covered it. I had noticed that it seemed to be wearing away. Good Luck.
Old Dec 27, 2023 | 12:46 PM
Oh that is a good call. I didn't realize this still may be covered under warranty. I might still be within the window as the car is 2019 and under the mileage limit.
That would be a blessing if warranty covers. Seems like a lot of work after looking at the service manual and ebay parts photos. I am left with two options.
1. Dismantle the headliner to unplug the various wires to detach the harness.
2. Dismantle the liftgate trim and unplug the various wires to detach the harness.
Old Dec 27, 2023 | 01:50 PM
Well you have a third option and just live with it. That was what I was going to do. It did take the shop foreman at the dealership to advocate with JLR to get it covered. Good luck.
Felixbobcat
42
Feb 2, 2023 05:47 PM
3timejag
Jul 21, 2021 07:26 PM
Rogelio Serrano
Nov 23, 2016 03:54 AM
MK2
Mar 31, 2015 11:30 AM
