New F type- Active Exhaust question
Old Sep 8, 2017 | 01:59 AM
AbF's Avatar
AbF
Originally Posted by ek993
Which fuse did you remove?
Fuse 43, isn't this one? I removed from under the passenger floor mat.
Turned the car on after that and nothing.. changing to Dynamic I could notice the difference..
Old Sep 8, 2017 | 07:40 AM
v6madness's Avatar
I have base 2017 with Standard Active Exhaust in Australia and apparently standard Torque Vectoing via breaking
Old Sep 8, 2017 | 02:31 PM
Unhingd's Avatar
if you have the super performance brake option (376mm rears), you have Torque Vectoring
Old Sep 28, 2017 | 12:00 PM
MrRay's Avatar
Default F-Type MY2018 V6S
Have the V8 X-pipe mounted on the V6, gives a ruff sound but no significant sound level change. They tried to mount the exhaust switch which is missing on my car but that seems impossible on the 2017 and 2018 MY, the switch is no longer detected, this is software related and can no longer be changed as in the past. I will need to find another way to command the exhaust control valves.
One lesson I learned, never by a F-type without the exhaust control button.
Old Sep 29, 2017 | 11:36 AM
MrRay's Avatar
Here's a pic of the V8 X-Pipe mounted on my V6 S,.
This gives a raspier sound but as the exhaust button is missing on my car the effect is almost unnoticeable under 4000 rpm.
The dynamic mode button has no effect on the exhaust solenoids whatsoever.
Anyone has a solution to this or knows a company that has and this without pulling the fuse?
Old Sep 29, 2017 | 05:34 PM
FR500GT's Avatar
Nice! Glad to see it bolts up without any issues. I would think that the car would sound deeper with the new X pipe, no? Louder idle? Any drone?
Old Sep 30, 2017 | 03:05 AM
MrRay's Avatar
Hello FR500 GT,
The sound is a bit louder at idle and gives a tinny sporty rattle on acceleration, concerning the drone I can't tell, need to pull the fuse. I have the active exhaust but without the button which I regret.
As I wrote before, active exhaust only opens at 4000 rpm, selecting the dynamic mode makes no difference. For that point I regret my F-Type base 2014 with the exhaust button. Would have liked that my car sounds like the 400 sport.
Old Oct 4, 2017 | 07:27 PM
  #28
Stuart@VelocityAP's Avatar
Originally Posted by MrRay
As I already wrote I'm thinking a août changing the after Cat section on my F-type S. I still there any chance that the V8 center OEM exhaust section will fit plug and play in between the stock Cat and the Backbox?
Anyone tried or has experience in this?
Yes it will fit.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Old Oct 5, 2017 | 03:28 AM
MrRay's Avatar
Originally Posted by Stuart@VelocityAP
Yes it will fit.
I confirm, V8 X-pipe was installed on my V6 and bolds on plug and play.
Makes a hell of noise on start-up, this quickly disappears when the active exhaust closes.
Sounds more like the V8 now, it's a pity that I don't have the active exhaust button in the cabin.
Old Oct 15, 2017 | 07:13 PM
  #30
Costa28082011's Avatar
Hello Bigdaddy,
I drive an F-type S with the active exhaust.
The kit that I talked about is for a standard 340 and can be found here;
https://www.jaguar-shop.com/epages/6...ucts/T2R14178U
hi there will this kit work for mine my model is
2014 Coupe 51,000 miles Automatic 3.0L Petrol Jaguar F-Type 3.0 V6 Quickshift 50,000 Miles - Being Used Dymanic Mode
Engine power 335 bhp Engine size 2995 cc Brochure Engine size 3.0 litres Acceleration (0-60mph) 5.1 seconds Top speed 161 mph Drivetrain Rear Wheel Drive
Any help will be much appreciated thanks
Old Oct 16, 2017 | 09:35 AM
  #31
MrRay's Avatar
The Kit will fit a 2014 F-type.
Finally I decided to mount the V8 X-pipe on my F-type S 6 cylinder, it is plug and play and gives a sportier sound way loud enough to wake the neighbours on start-up
I think that with a non active exhaust damper, the one that is mounted on your car, it will make an even lower sound and that for around 400$.
Old Oct 16, 2017 | 09:38 AM
  #32
[QUOTE=MrRay;1776663]The Kit will fit a 2014 F-type.
Cheers[/QUOTE
thanks for response have you got a link for this if. It whre can it be purchased?
Old Oct 16, 2017 | 09:45 AM
  #33
MrRay's Avatar
Hello,
Just to let you know that the more I start the car the louder it gets.
Still no cracks and pops when I drive the car but on acceleration it has a nice metallic rattling sound that I recon is caused by the X-pipe.
I appreciate this sound more and more.
Me like that
Old Oct 16, 2017 | 01:15 PM
  #34
MrRay's Avatar
[QUOTE=Costa28082011;1776664]
Cheers[/QUOTE
Part nr 6 on this web page
https://parts.jaguarpalmbeach.com/a/...M/4760335.html
