New noise
Old Nov 2, 2023 | 10:00 AM
jadenjames's Avatar
Default New noise
Hey everyone,
I have strange noise being heard from the front left wheel well on my 16 F type R and just wanted to get your guys opinion. I only hear it in 1st and second gear higher in the rev range. Sounds like maybe a dull metal rubbing or tire rubbing sound. My thoughts are wheel hub, motor mount or half shaft. Only things that have changed in the last 3 months was replaced break pads and had a torn CV boot on the same side as the sound that was replaced at the dealership. They “fixed” the boot but had to come back about a month later as it was not fixed and leaking grease again. No issues since.
Thanks for your time
Old Nov 2, 2023 | 06:31 PM
T-Money's Avatar
Originally Posted by jadenjames
Hey everyone,
Hi there, I doubt this is the same issue based on your description but I did have a tire rubbing sound on my 17 F-Type R that was heard at low speed and in particular when turning the wheel. Turned out that the wheel-well line had drooped down just enough to catch the edge of the tire when turned. I was able to loosen the hardware and lift the liner up just a hair and the issue went away. Good luck!
Old Nov 3, 2023 | 07:47 AM
BigJay13's Avatar
Thank you T-Money for putting your response. I came here this morning to ask the exact question that you just answered about my 17 F-Type SVR. I thought it was a rubbing sound but haven't been brave enough to get under there yet and look around. I'll do that this weekend. Thanks again and have a great weekend.
Old Sep 8, 2025 | 01:45 PM
jadenjames's Avatar
Update it was a worn engine mount and under load was scrapping the block
Old Sep 9, 2025 | 03:29 PM
eeeeek's Avatar
I was going to guess a motor mount as I had a very similar issue in a different car. I had someone rev the engine while I was looking at it and it was immedieately obvious.
Mac Allan
Apr 23, 2024 08:19 PM
TBanks98
Oct 2, 2021 05:05 AM
Stamford
Oct 4, 2014 11:27 AM
erdoc
25
Mar 18, 2014 06:33 PM
Spikepaga
Jun 7, 2013 04:03 PM
