? new sound MY19 R
Old Oct 16, 2020 | 06:44 PM
Pie944's Avatar
Originally Posted by OzXFR
Makes no difference either way, that centre metal piece is the oil extraction tube and it goes all the way down into the sump and sits around 5 mm off the bottom.
I find it easiest to put a funnel in between that tube and the edge of the oil filler hole.
Yup, searched through old threads and figured it out. 1 quart in. Waiting before checking the level.
Old Oct 16, 2020 | 06:55 PM
Pie944's Avatar
So waited after the first quart, still says under filled and didn't budge in terms of the markings. I added a second. Waiting 5-10 more minutes. At this point if the level doesn't budge do I call for a flatbed to take it to the dealer Monday morning, or keeping adding and checking?
Update: Second quart didn't budge, setup the flatbed for tomorrow morning and appointment is Monday. Honestly, the setup of the flatbed was so pleasant I'm still in shock.
Old Oct 20, 2020 | 10:18 AM
Pie944's Avatar
Latest. They are going to keep the car for a few days to make sure no leak with oil level being low.
The check engine was on when the guy came with the flatbed. When I asked the service advisor on the phone about the light they said it was associated with the super charger?
Thoughts in general?
Old Oct 20, 2020 | 11:08 AM
DJS's Avatar
DJS
A number of us have gotten (or about to, in my case) a new supercharger snout, to replace failed bearings or the isolator/coupler. Not terribly rare, unfortunately. Quite expensive at a dealer when not covered by warranty. Wouldn’t think that would be related to loss of oil, but I’m no expert. My S.C. couple is quite noisy, with no loss of oil.
Old Oct 20, 2020 | 04:45 PM
OzXFR's Avatar
No possible connection between SC rattle/noise and low engine oil, the SC is a sealed unit (other than air flow duh!) and has it's own oil.
Old Oct 21, 2020 | 02:38 PM
Pie944's Avatar
Loose oil filter. No issues with further drops in the oil and they’ve had it for a couple days. Super charger fixed
Big personal lesson is check the oil level more frequently. My biggest issue is waiting the ten minutes, but I’ll start checking before driving every day and attempt to sit in the car to check post more frequently.
Ventura County Ry
Jul 31, 2020 08:29 PM
camstang6907
Apr 12, 2020 10:42 PM
Eloquaint
Sep 20, 2019 06:26 AM
lunagry
Oct 19, 2014 04:15 AM
Master Deep
Jan 25, 2014 08:51 PM
