New Wheels
Old May 20, 2022 | 09:27 AM
RIRR's Avatar
Default New Wheels
PO-1 Forged Monoblocks from MRR Design Wheels…
Old May 20, 2022 | 09:46 AM
supersportmtl's Avatar
Very nice setup! Enjoy!
Old May 20, 2022 | 02:09 PM
shrinktfit's Avatar
Wish I could generate enough interest in the Vorsteiner 103 wheels to get the mfgr to produce some more! https://vorsteiner.store/products/v-...42393482100906. Been sold out for awhile.
Old May 20, 2022 | 04:14 PM
BruceTheQuail's Avatar
That's what I've got, look fantastic and the handling improvement from the lighter wheels is epic! Easy to clean too which is a big thing for me.
OP, your wheels look amazing. Have you noticed a handling/ride difference? It is very noticeable in the 6 (especially direction changes, eg coming out of a roundabout), not sure about the 8.
Old May 20, 2022 | 05:51 PM
RIRR's Avatar
I haven’t driven the car enough since the change to tell a big difference, but I lost about 10 pounds per wheel in front and 13 pounds per wheel in the rear. I expect to notice a big difference as I drive the car on some curvy roads.
Old May 20, 2022 | 08:12 PM
Madrona1's Avatar
Wheels look very nice makes me think about changing.
Old May 20, 2022 | 08:54 PM
RIRR's Avatar
The color of the wheels is similar to the color of the car in that they both look noticeably lighter or darker depending on light conditions and viewing angle. I debated whether to go with a solid color, but I am really happy with the translucent Brushed Dark Tint color.
Old Oct 20, 2022 | 03:24 AM
JonWat's Avatar
Yes, they look good but worth spending a couple of grand on? Nah
Old Oct 20, 2022 | 03:59 AM
I put forged on mine and disregarding the fantastic looks, the handling improvement was incredible, really transformed the car. It was worth every penny of what I paid, and it was quite a bit more than a couple of grand. It'd be interesting to see how they would go on an XKR, though from when I had mine the issue was getting the power down and also dts interference when traction breaks (neither of which is really an issue in the f type with different suspension), so I'm not sure whether light wheels would help.
Old Oct 20, 2022 | 05:31 AM
bfrank1972's Avatar
I second this, folks may not understand just how much reduction of unsprung weight can help the car manage contact with the road. Especially when considering how heavy most of our stock Jag rims are folks will drop a couple grand on coilovers no problem...
Old Oct 20, 2022 | 11:17 AM
ToysARs's Avatar
Aggressive offsets yet classy, nicely done! Would you mind sharing the wheel specs? Also have you weighed them by any chance?
Old Oct 20, 2022 | 05:17 PM
So true, even on the mustang, swapping over the OEM 19's for wider forged 20's was a big improvement with handling, especially direction changes. You still feel that weight, but much less understeer. Add a strut brace (jury out whether the improvement is just in the mind, I am convinced it does help), and it is actually a bit of fun even in tight turns.
Old Oct 21, 2022 | 09:37 PM
RIRR's Avatar
Front: 9 x 20, 35mm offset, 25.4 pounds; rear: 10.5 x 20, 28mm offset, 27.2 pounds. Weights are from a bathroom scale that weighs in .2-pound increments.
Old Oct 22, 2022 | 09:43 AM
shrinktfit's Avatar
Any informed comments on the 21" vs 20" wheels on the F-type?
Old Mar 4, 2024 | 05:45 PM
Pupilbone's Avatar
Running 21’s would certainly make the ride suffer some. They look great, but this makes for more of a street cruiser. The bigger wheel plays a trick with the eyes and makes it look lower even though it isn’t. The wheel gap doesn’t change, just the sidewall on the 21” tire reduces, hence a stiffer ride. The overall diameter of the wheel/tire cannot change regardless of the size of the wheel. I just went thru the pros and cons for this choice and eventually ordered some 20” Vossen forged with Yokohama Advan Neova AD09’s. 20 x 9 front with 265 35r 20’s. 20 x 12 rear with 305 30 20’s. on the Vossen site there are a few F Types in the gallery where the owners went with 21’s and 20’s. You can compare the look easily there. Hope that helps.
Old Mar 4, 2024 | 06:15 PM
Forged 21's with michelin rubber ride better than OEM 19's with P-zero, save in dynamic on a bad road where it gets a touch more jiggly. The Jag service guys had to deliver my car to me, they couldnt believe how good the ride was.
Unfortunately I cant say the extent to which the improvement is due the forged rims, or the michelin rubber
Old Mar 7, 2024 | 08:09 PM
samit's Avatar
Looking great! That's the stock wheel size, but compared to OEM offsets, the wheels are 20mm further in front and 10mm in the rear? Have you noticed any rubbing in the front?
Old Mar 9, 2024 | 07:46 AM
jcb-memphis's Avatar
They look really good but I suspect in person they are much better given the complex 3d design.
pjazz
May 20, 2022 04:34 PM
htrdlncn
Apr 16, 2021 11:58 PM
jahummer
Mar 1, 2015 08:25 AM
carreragt7
23
Sep 20, 2009 05:02 PM
Supralative
Jul 2, 2009 06:51 PM
