No-profile tires
Old Aug 23, 2025 | 06:00 AM
Robert Fahey's Avatar
Default No-profile tires
I have a 2024 Audi RS6 which came with 285/30s -- and I've lost four tires already due to potholes and "raised structures" during construction. I'm close to buying a 2016 F-Type R, but I see they wear EVEN LOWER profiles on the rear. Has anyone looked into getting tires with more sidewall? What did you find out?
Old Aug 23, 2025 | 06:39 AM
bfrank1972's Avatar
https://tiresize.com/tires/Jaguar/F-Type/
If you want an R, I think the 19" rims (stock) will barely fit over the R brakes. That will get you 40/35 profile rims and keep you at the stock diameter. If you go for a V6 car with the smaller brakes you can go with the smaller rims and even more sidewall.
Old Aug 23, 2025 | 09:43 AM
lizzardo's Avatar
The 19" wheels fit over the Super Performance brakes that came on the R. That's how I ordered my car. There's not a lot of room between the caliper and the inside of the barrel, but that's only a hindrance when washing.
Old Aug 23, 2025 | 03:06 PM
eeeeek's Avatar
The stock R tire size, 295/30/20, is not lower profile than 285/30s
Old Aug 23, 2025 | 05:26 PM
lizzardo's Avatar
The standard tire sizes for the 19" rims are:
245/40ZR19
275/35ZR19
These are narrower than standard R tires, but do have a little more sidewall. There were 18s available too, but I don't think they'd fit over the Super Performance brakes that can standard on the R.
Old Aug 24, 2025 | 06:20 AM
Your'e right. The fronts are actually 35s; rears are 30 (same as my RS6) -- at least on the one I'm going to buy.
Old Aug 25, 2025 | 05:01 AM
scm's Avatar
scm
Not the same if your RS6 is 285 - the 30 denotes the percentage of the width as the height of the sidewall, so a 295 wide tyre has a slightly higher sidewall.
Tom61
Apr 28, 2022 10:16 AM
GranTurismo01
Apr 8, 2022 10:49 AM
crashxx
Jun 21, 2021 12:56 PM
Frenchy
Jun 6, 2015 11:36 AM
