Non-lithium lightweight battery option?
Old Dec 20, 2022 | 10:47 AM
jcb-memphis's Avatar
Default Non-lithium lightweight battery option?
Hi,
I tried the 60a Anti-Gravity battery and it and my car did not mesh well...it was if my car could not charge that battery. Have had success in P-cars with AG batteries....
But before I went lithium I used to use smaller AGM units. Does anyone have experience with trying the 21lb Deka/Braille unit? It has enough CCA/cranking amps but lacks the total reserve of our 70 lbs monsters.....
In DEKA form they are about 150 dollars too....so tempting. Anyway, wondering if anyone tried this out as I had used this in a 996 gt2 with great success....but in a car with probably 90% less networking in it.
Curiious on any and all experiences with non-litihium weight savings options on the battery....70 to 20 lbs seems like a good thing. I use the car every day or every other day and have shut off "auto stop/start" ....so perhaps I don't need as much battery....
TIA
jcb
Old Dec 20, 2022 | 10:57 AM
mcphill's Avatar
The car seems very sensitive to battery voltage. I personally would not mess with the OEM system unless you are trying to shave weight at the track, and restore to OEM when done.
Old Dec 20, 2022 | 05:57 PM
Thanks. You are probably right...you just saved me a lot of dollars and time....so I went to your sig and got he LED bulbs. Now it will be just like a 992.
Again, thank you.
Old Dec 21, 2022 | 10:45 AM
Austin7's Avatar
I've run this in my XE for a couple years with zero problems. https://braillebattery.com/products/i34x
Old Dec 22, 2022 | 05:33 PM
samit's Avatar
I had the exact same issue with an Antigravity battery and a quick BMS reset using my iCarsoft LR V2.0 code reader fixed it. I'm sure there are plenty of other code readers that can do this too. Zero issues for two years now after the BMS reset.
Old Dec 22, 2022 | 07:29 PM
Thanks.
Wish the dealer would have been a little more helpful.....blamed the AG battery so I sold it at a moderate loss....ug.
Old Dec 25, 2022 | 07:14 AM
cujet's Avatar
I really like the Odyssey batteries. They are quite robust, and do last. We use them in aircraft with fantastic results. Great cranking power! A 23 pound Odyssey battery replaces an 80 pound conventional battery, no problem.
Jagstefano
Dec 26, 2018 04:25 AM
nasomi
Aug 13, 2017 09:16 PM
DRV4SHOW
Aug 10, 2017 06:23 AM
Cadillac
General Tech Help
Sep 23, 2014 12:39 PM
SV8Predator
Apr 12, 2009 04:26 PM
