Which OBD scanner is best suited for our cars?
Received 3,126 Likes
Anyone know which bluetooth scanner works well on these cars? I have always bought a small obdll bluetooth scanner I can use with my phone at all times in every car I've owned. Saw that some may cause issues, so I don't want to waste money and buy the wrong one. Just looking for a confirmation on one that works. Will the plx work? Thanks
Just make sure you get a decent quality elm327 and not one of the cheap Chinese knock-offs.
I bought mine a few years ago so sorry I can't link to that one for you.
Nahla Artemis-Delphis (02-18-2019)
Unfortunately, there are a lot of reports that accessing the ODB2 often disables the car upon the following drive or two. It did to me. It lead to the dealer being very confused and doing a bunch of unnecessary software loads that became a long and painful story.
So, not recommended for the Jag.
I use an elm327 with the Torque app (android) connected through bluetooth, works perfectly and never had any electrical or battery problems.
https://www.amazon.com/Scanner-Bluetooth-OBDATOR-Diagnostic-Android/dp/B074DWH8JR/ref=mp_s_a_1_1_sspa?crid=1P4AGDLBL2636&keywords=el m327+obd2+bluetooth&qid=1550582747&s=gateway&spref ix=elm+327&sr=8-1-spons&psc=1&smid=AH3WM46J9THPR
Maybe this one: Edit - your link works in my post, and maybe yours is a better version than the one I linked to.
I use the OBDLink MX+ BT adapter as is specifically powers down after 2 hours. Plus it's 3 times as fast as next fastest adapter.
I plan to leave it installed in the car from now on. It's a bit expensive at around $100. So far it works good and the car is still doing the start/stop thing. I found this is a great indicator of battery charge. If not stop/starting then the battery is not topped up.
But I just saw it on sale here for $80!!
OBDLink MX+
OBDLink MX+
My i930 icarsoft can't read the engine module on my 2004 XJ8.
All sorts of engine module info on the 2007 XJ8 VDP,
Unable to upgrade, and no answers to my E Mails, W T F.
Really like the reader, except this one glitch it works great.
Anyone know of a reader able to read the 04 engine module ???????????????
#28
#30
#31
#34
#35
So, you are suggesting that an OBD device can be safely plugged in by immediately rebooting the battery management module (momentarily disconnecting battery) after the plug-in?
#36
Not exactly. My car immobilized on the drive after I plugged in my BT OBD2 module. I left it plugged in to work with TorquePro. After leaving it with the dealer for a couple of weeks while they figured out how to clear the problem, they said some cars crap out the first time a customer (they probably said cheap) OBD2 reader is attached. I don't know what they did to clear it, but they called a few times to explain they were struggling to figure it out and fix it. After they gave the car back it has been fine. I thought it might have kept the car alive, maybe creating voltage issues during the next drive. But whatever the cause, it's been fine since just like they said it would.
#37
#38
That’s good to know😉because I bought the iCarsoft LR 2.0 based on your recommendation last week.👍🏻
#39
That's great, agreed they make a really nice piece of equipment, but back to the original issue.
So far it appears no one makes a reader able to get ANY information from my 04 engine module W T F.
Main reason i posted over here, is so far no luck on the 03-09 section of this site.
Looks like the dealer level type of scanner programmer, is what it's going to take.
Any suggestions???
Any suggestions???
#40
I recently bought " Autel Maxidas DS808 Diagnostic Tool OBD2 Scanner:" . It has great battery backup, a lot of features and the tech support is also amazing. It's a great product. You Should read more about OBD2 scanner here before purchasing so that the product suites your needs.
