OEM P7 Grill Available (limited), Righting a Wrong, F-Type Resource
Old Mar 15, 2024 | 01:38 PM
lizzardo's Avatar
Originally Posted by JagFR
As for the badge, impressive how you got the "Jaguar" covered in red. I wouldn't be able to cover that.
I did something similar to restore some plastic hubcaps. They're silver with inset black lettering. I masked everything, cut out the lettering with an x-acto knife, and gave a shot of gloss back to the lettering. The second step was to do a reverse masking. There is a paint-on masking material that I used in the letters, then I shot silver over everything. I used a few coats of the liquid mask to make it easier to peel off. It dries to a rubbery consistency, so I used a pin to lift a corner and peel it off.
Old Mar 16, 2024 | 12:20 PM
Dillweed's Avatar
I'm preparing to install my grill and need some advice on mounting the front parking sensors in the plinth provided by Dudley. The oem grill has a clip that holds the sensors .... the plinth from Dudley doesn't. Is it ok for me to silcone glue the sensors in place to the back of the plinth with the sensor eye poking thru the front of the grill?
Old Mar 27, 2024 | 03:34 PM
skizot's Avatar
Yes that is how most do it.
Old Mar 27, 2024 | 03:37 PM
skizot's Avatar
@PaulBarrrera and others. I was able to have time today to pull the front bumper, modify the plastic cover (requires some plastic trimming. Modify the front bumper (requires some plastic to be cut away) to get the P7 grill installed. It is coming along. I should have time Friday to finish it up.
Old Mar 29, 2024 | 10:32 AM
skizot's Avatar
Done!!
Old Mar 29, 2024 | 11:05 AM
Dillweed's Avatar
It looks great, Skizot!
I'm going to use The Rock's suggestion and have purchased a 2.5" strip of black plastic to cover my inner frame behind the grill. If it isn't storming too bad here in LA this weekend, I'm thinking of installing my grill. I am definitely not looking forward to crawling under the front end to remove the zillions of screws/bolts others have described when doing this job, tho. . Any shortcuts to this process you can share?
Old Mar 29, 2024 | 11:14 AM
JagFR's Avatar
Wow, it looks stunning! You have just entered the super exclusive esteem club of Ftypes. Congratulations!
I too am trying to work my way up there without breaking the bank. I have managed to source the p7 mesh grill, but the surround will add more expense to it. I was wondering if anyone knows whether the cheap eBay carbon surround is compatible with the OEM p7 grill?
Old Mar 29, 2024 | 12:41 PM
  #28
zochmenos's Avatar
Unfortunately, in my experience they are not. The honeycombs (or the surround) would have to be notched or otherwise modified. I ordered one hoping to solve the "black or body colour" dilemma and ended up returning it.
Old Mar 29, 2024 | 02:52 PM
JagFR's Avatar
Bummer. Thanks for confirming!
Old Mar 29, 2024 | 03:03 PM
  #30
skizot's Avatar
no short cuts. There is a lot you figure out as you go along. Definitely not just a bolt up. There is some cutting on the stock bumper to notch out where the plastic beam normally sits so the surround sits flush and some other trimming for the plastic cover too.
RickyJay52
Nov 9, 2022 07:28 PM
ubsvr17
Nov 8, 2022 02:52 PM
OzXFR
Jun 14, 2021 10:41 AM
HarryFType
Feb 15, 2020 09:40 PM
powerhouse
Nov 14, 2019 07:01 PM
