Official Jaguar F-Type Picture Post Thread
Old Dec 29, 2023 | 06:52 PM
  #4061
Carbuff2's Avatar
EVERYBODY needs at least one 'Vert in their fleets.
So, if you already drive a Camry Solara or VW Eos, an F-Type Coupe is for you! <<DUCKS>>
Old Dec 30, 2023 | 06:00 AM
  #4062
SassySarah's Avatar
Originally Posted by DJS
I’d accept that. As long as it isn’t white.
Especially if it's white!
Old Dec 30, 2023 | 09:21 AM
  #4063
crashxx's Avatar
Unless you live in western Oklahoma where the wind blows 40 all the time and covers everything with red dirt. LOL
Old Dec 30, 2023 | 01:27 PM
  #4064
Cgo's Avatar
Cgo
Originally Posted by PotholeAvenger
Picked her up today.
stunning!
Old Dec 31, 2023 | 10:07 AM
  #4065
DMeister's Avatar
Yeah, it's crazy how much that colour changes with light. You will never get bored. It will be like constantly getting a new car ;-)
Old Jan 7, 2024 | 05:52 PM
  #4066
ThunderKitty's Avatar
Default Finally- after months of looking
Brought her home yesterday.
Old Jan 7, 2024 | 07:43 PM
  #4067
peppersam740's Avatar
Very nice. I like that color.
Old Jan 9, 2024 | 07:59 PM
  #4068
Paul champagne's Avatar
Default Another nice sunset
Old Jan 16, 2024 | 03:00 PM
  #4069
badal38257's Avatar
Old Jan 17, 2024 | 08:54 PM
  #4070
LaserMark4's Avatar
Default Pretty Jazzed for the new addition!
Old Jan 17, 2024 | 09:10 PM
  #4071
Love that color AND the low miles.
Old Jan 17, 2024 | 09:19 PM
  #4072
DJS's Avatar
DJS
Have you learned to slam the hood from the middle, so it latches evenly? Check to see if the sides are flush after closing.
The first F-type I test drove, and the first I ever saw, was a Firesand V8S in May of ‘13. Herb Chambers then took it as his personal car for a while.
Old Jan 17, 2024 | 09:43 PM
  #4073
LaserMark4's Avatar
Awesome! Sounds like you are an F-Type veteran from way back. I am pretty new to the roadster-- but I am loving it! And yes, very careful to lift the hood from the center and then use the vents to slowly and gently close. The seams and gaps of the body panels throughout the vehicle are still remarkably square.
Anticipating the obvious coming, I'm just about to do a preventative overhaul of the coolant system with metal/aluminum parts, including the dreaded upper/Y-pipe and all plastic hoses, fittings, etc. At the same time while it's all torn down, we're going to replace the water pump, the thermostat cyclops (with the new aluminum/metal one), supercharger oil, SC coupler, the coolant line under the SC, change the SC and accessory drive belts, flush the coolant (and diff fluid), add the Mina Gallery upper intake tube kit (to replace all that crap intake plastic), and then button it back up. A great, local indy shop is allowing me to purchase all the parts, fluids, and leg work and they will be doing the labor.
Wish me luck- 😎
Old Jan 18, 2024 | 10:31 PM
  #4074
diablo2112's Avatar
2017 R - 46k miles
Old Jan 19, 2024 | 01:37 AM
  #4075
OzXFR's Avatar
Never done it that way and never had a single problem.
Instead I simply let it drop from around 40-50 cm.
No fuss no muss no slam and perfect close every time.
Old Jan 19, 2024 | 09:00 AM
  #4076
Thunder Dump's Avatar
I wonder if you can do it this way because the gas struts on yours have weakened over time. On both my MY18 and my MY23, if I push the hood closed to about 40-50cm and let it drop it would just stay there, as there is enough upward pressure from the gas struts to hold it up at almost any position. It needs to be pushed down with mild force to latch.
Old Jan 19, 2024 | 12:30 PM
  #4077
Carbuff2's Avatar
I only JUST learned what these holes in the bonnet hinges were for!
Old Jan 19, 2024 | 01:08 PM
  #4078
badal38257's Avatar
What?? What??
Old Jan 19, 2024 | 01:14 PM
  #4079
I'll guess it's for a locking pin for the hood.
Old Jan 19, 2024 | 01:57 PM
  #4080
DJS's Avatar
DJS
It’s a cigar cutter.
