Oil Viscosity Topic
Old Jun 3, 2026 | 07:34 AM
Lothar52's Avatar
Default Oil Viscosity Topic
is anyone running 5W-20 or 5W-30 or even 0W-30 in their V6 or V8 Ftype. I have both Ftype engines. What has been your experience as far as engine noise, performance, and./or oil analysis results. I have several AJ Jags (five) and have been running 0W-20 but as we know as these engines get older they tick more (not injector related - possibly cam phaser?).... and from my 165k XKR certainly run less smooth (I do 3k oil changes myself with high quality 0W-20 synthetic).
Let me know if anyone has different oil viscosity experience!
Loth
Old Jun 3, 2026 | 09:27 AM
Rondog's Avatar
I have always used 0w-20w in my 2017 F-Type /R. The car is only driven in the summer ( June-Oct ) since I live here in Ohio. But after reading results from the Oll Guy and other test I have seen, I am prompted to change to 5w-20w at my next oil change. Seems like it would do more good than harm as my engine get older,
Old Jun 3, 2026 | 09:43 AM
calviroman's Avatar
You'll get the full spectrum of opinions on this. A significant factor in the answer is "across what range of oil temperatures will the car be started". For example, if you live in south Florida, the car is 100% garage kept, and in a year the coldest oil temperature it is started at is 60 degrees F., then a slightly thicker oil is an excellent choice i.e. 5W-30. If you live in Canada and frequently start the engine at an oil temp of -20 degrees F then you are best served by 0W-20. All that said, for most owners who live in moderate climates, it doesn't matter and any quality oil between 0W-20 and 5W-40 changed every 5K miles would serve just fine.
Old Jun 3, 2026 | 10:10 AM
Lothar52's Avatar
Hey Hey im in cbus as well... 19 Ftype R in caldera red and 17 Ftype S in metallic black. You belong to the Jag Club?
Loth
Old Jun 3, 2026 | 12:39 PM
RGPV6S's Avatar
Loth
The fill cap on my engine says to use 5w-20 so that is what I always use.
Old Jun 3, 2026 | 01:38 PM
Nick R's Avatar
*Most likely* your engine won't bat an eye at a 30 weight oil, but in the end it's up to you to decide.
Old Jun 3, 2026 | 03:11 PM
cpq100's Avatar
This topic was just discussed in another thread. See the thread below.
https://www.jaguarforums.com/forum/f...or-oil-296626/
TM1238
Oct 15, 2025 08:33 PM
calviroman
Nov 2, 2024 02:35 PM
monacoftype16
US Southwest
Oct 30, 2024 10:56 AM
Whalesmash
Mar 16, 2022 09:46 AM
nickko11
Jan 30, 2021 09:51 PM
