P0162 and P0164 after service - something loose?
Old Aug 4, 2018 | 08:18 PM
lizzardo's Avatar
Default P0162 and P0164 after service - something loose?
I got a "check engine" light right after my annual service, and can't get the car back to the dealer until Wednesday. Has anyone seen this, perhaps as a result of something that came loose or wasn't reconnected? The codes are P0162 and P0164: Bank 2 sensor 3, malfunction and high voltage.
I'm sure the dealer will take care of it, but it's pretty hot here and my backup car has a really anemic A/C system (it's all anemic, really, but it has its charm) and I'm missing modern climate control.
Old Aug 4, 2018 | 09:17 PM
Unhingd's Avatar
Left side of car, the third o2 sensor (last one) is either disconnected or toast.
Old Aug 4, 2018 | 09:43 PM
lizzardo's Avatar
I wasn't sure if left or right, but that's the most obvious cause. Not sure why they'd disconnect it for service, so was hoping someone might chime in with "oh, yeah, if a particular vacuum line come loose you'll see that."
I'll take a look in the morning, before the asphalt melts (exaggerating, it shouldn't top 94F tomorrow). Still, morning will be best. Was hoping I'd be up to installing the Wortecs, but I don't think I'm ready yet.
Old Aug 5, 2018 | 05:08 AM
RGPV6S's Avatar
If the sensor is toast its pretty easy to replace. That sensor went bad in my car and I replaced it myself. Took longer to get the new part and jack up the car than install the replacement.
Old Aug 5, 2018 | 09:17 AM
lizzardo's Avatar
It's still under warranty so I'm going to let them handle it, unless I see something's come loose when I check it this morning. It happened the day I picked it up from service. I went about ten miles to work and then came home later. I noticed it after climbing the hill coming out of Berkeley. I had an unimpeded drive to the top, to put the engine under a little load. As noted, I was hoping this was a typical symptom of loose clamp or vacuum hose that someone had seen before.
Old Aug 5, 2018 | 09:27 AM
RGPV6S's Avatar
The sensor is located at about the middle of the car - the sensor is easy to see and the plug is a bit buried but still accessible to check for a solid connection. You only need to jack at the rear in front of the rear wheel well (at a jacking point) and the front will also lift. However I would use safety stands or blocks
Old Aug 5, 2018 | 09:29 AM
lizzardo's Avatar
Thanks for the location information. I was going to jack the front. As for stands: always.
EDIT: It all looks in order from visual inspection. <sigh>
Miss Muffet
Oct 25, 2016 05:56 PM
Spikepaga
Sep 13, 2013 11:35 PM
Qgregg
Mar 27, 2012 04:38 PM
Oct 28, 2010 11:12 AM
djoseph43
Mar 16, 2010 06:37 AM
