Parking brake require calibration
Old Sep 18, 2022 | 08:30 PM
kpholsith's Avatar
Exclamation Parking brake require calibration
I changed my brakes and rotor at a reputable shop here in the bay, they specialize on track cars and such.
after changing everything 1 week later i tracked my car at Thunderhill West ( 2-3mile track) everything was great, the race brakes i put on are amazing, they bite and low brake dust than OEM !
So today 1 day after track day I was parking my car and this -refer to screenshot- came up. What does this mean? What could be the cause of this?
I went on google and found the solution to calibrating the brakes, I did the press on foot brake 5 times and pull electronic brake. it went away. Then I drove somewhere and it came up again. Had to repeat the same process and went away. Hopefully it doesn't come up again. If it does, should this warrant a dealer visit? Car is out of warrenty
Anyone had experience with this? What could be the cause?
Old Sep 18, 2022 | 09:11 PM
OzXFR's Avatar
In an earlier thread you said you bought new Brembo discs/rotors and Porterfield R4-S pads.
Did you use those pads for this track day or some other pads eg R4?
Just curious to know that if you used R4-S how well they went on a track day as a few here have said that R4-S are no good on the track.
Old Sep 18, 2022 | 09:12 PM
kb58's Avatar
Check the obvious first; shine a light in on the brake pads and ensure they still have plenty of pad thickness. Yes, I know they're new... do it anyway to rule out something goofy going on.
Old Sep 19, 2022 | 02:15 AM
kpholsith's Avatar
So i drove home after work and this came on again but went away after I turned off and restarted the car.
Old Sep 19, 2022 | 07:59 AM
Carbuff2's Avatar
X2
I know of folks who have worn out NEW sets of pads in ONE DAY of track time...
If the pads are OK, I'd look up putting the parking brakes in and out of Maintenance Mode.
(Even the BEST shops forget to read the directions. The technician was probably male!)
I've said it before, and I'll say it again...
"Brakes are for SISSIES"
Old Sep 19, 2022 | 09:44 AM
scm's Avatar
scm
And they waste fuel! ;d
jagophile
Aug 18, 2020 05:54 AM
pelle
Jan 25, 2018 09:16 AM
biffta
Aug 20, 2016 02:53 AM
flyrr100
Nov 6, 2013 05:56 PM
MRomanik
Sep 12, 2013 09:46 PM
