Parking Challenge
Old Jan 28, 2015 | 04:31 AM
RickyJay52's Avatar
Originally Posted by OzRisk
One nice little feature I do like is the way the side mirrors turn themselves downward when you go in to reverse so you get a better view of the rear wheel arch area. Is that standard on all models?
Side mirror as only the passenger side mirror points downward, and can be adjusted by the driver. I suspect, but don't know for sure, that it's standard across the board?
Old Jan 28, 2015 | 04:41 AM
OzRisk's Avatar
Thanks. Yes, you are quite right. Passenger side only.
Old Jan 28, 2015 | 09:17 AM
DJS's Avatar
DJS
It's a menu option, 'auto dip' I think it's called.
Old Jan 28, 2015 | 10:10 AM
buickfunnycar.com's Avatar
Originally Posted by DJS
It's a menu option, 'auto dip' I think it's called...
And I don't believe it's offered on the base coupe...I wish it was because both mirrors dip on our Lexus and it really helps backing up.
Old Jan 28, 2015 | 11:21 AM
DJS's Avatar
DJS
Unclear - this is one of those features that's poorly documented in the manual. The section that describes it in my manual (under 'mirrors') doesn't say that it isn't available on all models. But it says to refer to the 'Instrument Panel' section, and the menu options specifically. Of course, there's no reference to it there.
Old Jan 28, 2015 | 12:05 PM
Unhingd's Avatar
Maybe it's only available with the visibility pack?
Old Jan 28, 2015 | 01:12 PM
DJS's Avatar
DJS
I don't have that. Think I stumbled on this feature when I went through the menu to see what was in there.
Old Feb 2, 2015 | 03:55 AM
  #28
alexg's Avatar
I use the auto dip feature. Very useful and use my mirrors. Take my time, park it swish.
Old Feb 2, 2015 | 03:57 AM
StealthPilot's Avatar
Is there a switch to toggle auto dip or do you have to go through the menu? I find it useful for parallel parking but not for regular Parking.
Old Feb 2, 2015 | 04:01 PM
  #30
LynxFX's Avatar
You have to go through the menu.
I like the auto dip but I also wish it had a quicker toggle as there are times when I need to back up and see what is behind me on the right hand side.
I would take that button on the steering wheel vs the useless "set max speed" button.
Old Feb 2, 2015 | 04:24 PM
  #31
DJS's Avatar
DJS
If you exceed 7.5MPH in reverse, auto-dip is cancelled. So, the answer is to back up faster.
BTW, you can adjust the position while it's dipped, and that's the position it will use next time it dips.
Old Feb 2, 2015 | 11:14 PM
  #32
necoblitz's Avatar
I'm not sure whether the auto-dipped position is stored in the three memory settings for the seat, I know the baseline mirror position is. Is it is, you could set an undipped position in one of the memories and use that when needed. Just a thought.
Old Feb 3, 2015 | 03:32 AM
  #33
LynxFX's Avatar
hmm I might have to try that out.
Old Feb 4, 2015 | 06:40 PM
  #34
ebbnflow's Avatar
I have an F-Type Base without Vis Pack and was advised by dealer (after some investigation) that mirror dip feature is not included. I searched every menu and confirmed their answer.
I really wanted the Vis Pack, but wasn't interested in the Prem Pack that I had to buy as a prereq. Basically would have been $7k for both on an already stretch budget of $78k.
To be honest, I'm downright scared of parallel parking this thing. I still struggle with the appropriate distance to pull up when parking in a normal spot, as well as horizontal positioning. Low visibility in this car is just not existent and I'm scared to scratch my 20" wheels!
Oh, my First World problems!!
Old Feb 4, 2015 | 07:06 PM
  #35
Foosh's Avatar
I assume from your account that you have a coupe. The visibility in my base convertible doesn't present any real issues. You can "manual-dip" the passenger-side mirror yourself, and I've found that useful on occasion to avoid curbing a wheel.
On the other hand, I do try to avoid parallel parking, not because I find it all that difficult, but because I don't want others "kissing" my car on either side. Too many feel that it's perfectly acceptable to lightly tap the cars on either side to ease into and out of a spot.
Old Feb 4, 2015 | 07:13 PM
  #36
DJS's Avatar
DJS
I too have a heck of a time centering the car in angled parking spaces, etc. I suspect it would help if I raised the seat, but I like being low in the car.
Old Feb 4, 2015 | 07:17 PM
  #37
Foosh's Avatar
Having owned a dozen or so low-to-the-ground roadsters, and sports cars, that's always an issue, and there isn't a "vision pack" available yet to assist with centering between the parking lines.
Old Feb 4, 2015 | 07:47 PM
  #38
Unhingd's Avatar
Set one of the seat memories to the highest setting and paint a P on the button.
Old Feb 4, 2015 | 09:27 PM
  #39
Foosh's Avatar
LOL . . . some of us don't have seat memory on our stripped-down models. Simple is good.
Old Feb 4, 2015 | 10:59 PM
  #40
I too have a heck of a time centering the car in angled parking spaces, etc. I suspect it would help if I raised the seat, but I like being low in the car...
I'm with you exactly on that...I've had to raise the seat just a hair to see around me just a bit better but I'm failing miserably on parking because I'm erring too much on the side of caution.
I'm manually dipping my pass mirror when parking and cursing Jaguar under my breath,lol...
