Passenger Door handle can’t make up its mind
Old Aug 4, 2025 | 09:30 PM
Jkel72's Avatar
Default Passenger Door handle can’t make up its mind
Hi All:
in need of some advice/ wisdom
when I get in my MY17 the passenger door handle opens and closed four or five times.
sometimes it will pop out to the open position and other times it will pull back to the retracted / closed position.
Has anyone experienced this?
Does anyone have any suggestions to a solution?
This has only been happening for a few months but it seems to be getting worse.
JK
Old Aug 4, 2025 | 09:43 PM
DMeister's Avatar
Sounds similar:
https://www.jaguarforums.com/forum/f...ng-out-279257/
Perhaps reach out to Jag Bass and ask him what his resolution was, as he didn’t update the thread…
Old Aug 5, 2025 | 01:49 PM
cwisenheimer's Avatar
I had a similar issue and the fix was a new door latch assembly. I bought the part and spent 45 minutes installing it rather than have the dealer do the same job for $700 labor.
Old Aug 6, 2025 | 04:45 AM
DMeister's Avatar
Was the install info available in the workshop manual? How invasive was the install? I guess the interior door panel had to fully come off?
There’s something to be said for simple old school door handles. Everything is so darn complicated now.
Old Aug 6, 2025 | 08:01 AM
I just searched for some YouTube videos on the topic and found enough examples to figure it out. You have to remove the door panel, yes, but it's not complicated. The hardest part was getting one particular guide ferrule on the cable of the assembly to get seated into its intended bracket. That was just awkward and required some patience. Everything else was straightforward.
The shame of it is that the problem was inside a sealed latch assembly and was probably something that could have been fixed rather than replaced. If I had wanted a project, I might have tried to get the assembly opened and figured out a fix. Instead, I just wanted to use my car so I bought a part (which includes the latch, cable, etc.) and tossed the faulty part. BTW, I would avoid a used part in this case because the failure isn't readily visible or apparent.
platinummaker
May 13, 2023 09:28 AM
spotnag
Jun 14, 2021 07:24 PM
reds
Nov 3, 2020 03:15 PM
OldMike
Jul 1, 2013 06:47 AM
mv33rs
Jun 3, 2012 12:59 AM
